• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Distinguished Contributor
    Your Account has been automatically logged out of the ADMS.
    120 Views, 3 Replies
    04-04-2011 03:26 AM
    Hi All
    Wondering if you could help...
    If users are not working on their workstation for a while they get the following error:
    A problem occurred while attempting to retrieve folder information from the server.
    The server returned the following information: Your account has been automatically logged out of the Autodesk data management server. You must log in to access the vault.
    I thought that this might be a licensing issue and that a parameter may be set to automatically log out in-active users. I cannot however find any ADSKFLEX.opt file, or any *.opt files on the server so am not sure where this timeout variable would be set?
    Any Ideas?
    Brett
    ***Guru
    TravisNave
    Re: Your Account has been automatically logged out of the ADMS.
    04-04-2011 10:13 AM in reply to: BrettMOD
    This would be a connection issue to your SQL ADMS content database, not the network license manager.
    My Top Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Administrator | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combining .LIC Files | Search Autodesk Discussion Groups
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    02-09-2012 05:07 AM in reply to: BrettMOD
    Hi All
    This error has popped up again, We re installed ADMS a few months ago, and all went well again. Vault seems to run fine but then automatically logs you out again within 10 minutes or less. Running Vault Professional 2011. Please let me know if you have seen these errors before and what I can try and do to fix them. Restoring vault will take a few hours as the database is very large.
    Vault Explorer error:
    AutoCAD Error:
    Inventor Error:
    02-09-2012 05:10 AM in reply to: BrettMOD
    Sorry, I see that this post has been placed under installation and licenseing. I will try and move it to the vault forums rather.
