Installation & Licensing
Workstations show the license server system as “Server name”or “Distributed.”
2 REPLIES 2
bbali868
304 Views, 2 Replies
I recently upgraded servers and successfully transferred the Server license for one of my clients. They are pulling licensing successfully but are wondering why some of the client pcs show the network license entry as the actual server name and on some of the other client machines it shows up as 'distributed'. Would anyone have an explanation as to why this occurs.
2 REPLIES 2
TravisNave
in reply to: bbali868
It shouldn't matter, since a Distributed system is techically a group of single systems.  Is it possible that the client machines have the ADSKFLEX_LICENSE_FILE system variable set?
Autodesk Forums:
bbali868
in reply to: TravisNave
Thanks Travis  - I do believe some of the client machines have the ADSKFLEX_LICENSE_FILE system variable set which may explain the variance in names. Thanks for the response and explanation.
Administrator Productivity
