• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Distinguished Contributor
    Work arounds for borrowing a license using a docking station?
    131 Views, 3 Replies
    10-18-2011 06:55 AM
    i have a tablet (Motion CL-900) that has no physical NIC card, but rather it uses the NIC from the docking station.  when borrowing a license, the LMTOOLS server issues the license to the docking station rather than the tablet itself resulting in a failed borrow as soon as i remove the tablet from the station.
    per a suggestion by TravisNave, i've been playing with the microsoft loopback adapter and trying to "fool" LMTOOLS into thinking the tablet itself has a NIC card (rather than the docking station) and thus enabling a successful borrow to the tablet.
    so far i have not been successful.  has anyone else done this successfully?
    ______________________________
    ~ "if this were /. this would be funny"
    Please use plain text.
    Product Support
    Re: Work arounds for borrowing a license using a docking station?
    10-18-2011 06:48 PM in reply to: ssx_Autodesk
    Cool hardware....
    If you have a network license on Subscription, you may be able to use a home use standalone license.
    David Lau
    Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution. :smileywink:
    My 5 Top Issues in the Discussion Groups
    1402 Error [Uninstall] | Faro doesn't install | adlmPITSetProductInformation Errors | Empty Tool bar in AutoCAD Mac | Win 7 Registry Limit
    TravisNave
    10-19-2011 08:33 AM in reply to: ssx_Autodesk
    For reference purposes, the original thread is here:
    http://forums.autodesk.com/t5/Installation-Licensing/Borrowed-License-not-working-in-ACAD-2011/td-p/...
    Since there is no physical NIC, you might have luck cloning the WiFi card or even borrowing the license off the dock while connected via WiFi to the LAN.  Bypassing the dock altogether should work.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    10-19-2011 10:08 AM in reply to: TravisNave
    yeah, it looks like we'll be going the wifi route.
    thanks for your help
