Installing a network licence inventor 2011. Got the following error (Disk 6 is currently in the drive).
Windows - Wrong Volume
Exception Processing Message c0000012 Parameters 7c7df5f8 7c7df5f8 9d08f118 7c7df5f8
Insert the correct disc and do not remove it until you are prompted.
If you still have problems, copy all the contects of the discs into one single folder (overwriting when prompted) and install setup from there.
I never removed the disk. Any idea which disk it might want? It pops right back up regardless if I press cancel, try again or continue.
Try all of them!
Gotta love goofy Windows disc read issues. If you still have problems, just start all over and do the copy to HDD method.
