Installation & Licensing
Windows Installer Error..
8 REPLIES 8
Message 1 of 9
353 Views, 8 Replies
I have just setup ADT 3.3 on the FLEXlm. I am trying to install ADT on the
client work station. When I run the Setup.exe file I get an error "This
installation package could not be opened. Verify that the package exists and
that you can access it, or contact the application vendor to verify that
this is a valid Windows Installer package"
If I go into the IMAGE directory and run the client.exe I can install but
that is not a slient install.
Help...
Neil Sego
nsego@schmidt-arch.com
8 REPLIES 8
Message 2 of 9
Neil -
Make sure that there is a file in the image directory called ADT.msi. Also make sure that
it's size is 5,584,384 bytes (assuming that I have the correct build). This is a "Windows
Installer package". If it's not there you "might" be able to copy it form the root of the
adt cd to the image folder (anyone know if this will actually work??)
jason martin
frankfurt-short-bruza
"Neil Sego" wrote in message
news:33B33D4795699E4E7A7AAF1E9C0FBE28@in.WebX.maYIadrTaRb...
> Help...
> Thanks
> Neil Sego
Message 3 of 9
Thanks Jason, but there is an ADT.msi in the IMAGE directory and still no
success.
"jason martin" wrote in message
news:7A95F4B1B3878073A494FA015CBA639B@in.WebX.maYIadrTaRb...
> Neil -
Also make sure that
This is a "Windows
the root of the
> jason martin
the
and
but
> > Help...
> > Thanks
> > Neil Sego
Message 4 of 9
Did you create your client deployment using UNC pathing or drive mapping?
Skip Diercks
Computer Support Specialist
Wade-Trim, Inc.
sdiercks@wadetrim.com
Neil Sego wrote in message
the
and
> Help...
> Thanks
> Neil Sego
Message 5 of 9
I had a similar error recently installing some totally different software.
That was done from CD< not over the network, but the problem turned out to
be a registry path issue. Try looking at this MS KB article
http://support.microsoft.com/support/kb/articles/Q221/5/24.ASP?LN=EN-US&SD=g
n&FR=0&qry=Q221524&rnk=1&src=DHCS_MSPSS_gn_SRCH&SPR=FP2000
(watch out for word wrap, it's a long URL, and don't mess with the registry
if you aren't willing to take the chance that you'fll have to reinstall your
entire operating system from scratch)
news:2F2D4E75C987F6B541542E0AA0FD19A7@in.WebX.maYIadrTaRb...
> success.
> > Neil -
> Also make sure that
> This is a "Windows
form
> the root of the
> > jason martin
on
> the
"This
exists
> and
that
> but
> > > Help...
> > > Thanks
> > > Neil Sego
Message 6 of 9
UNC Paths
"Skip Diercks" wrote in message
news:01564E87DA741D059A0D9536DD438900@in.WebX.maYIadrTaRb...
> Skip Diercks
> Wade-Trim, Inc.
> the
> and
but
> > Help...
> > Thanks
> > Neil Sego
Message 7 of 9
Charles,
For future reference, you don't need to copy the big long url. Just copy up
to the ? like this:
- Tom
Message 8 of 9
That's good to know, thanks.
"Tom Gilmer" wrote in message
news:A9009E2899E0DD8A246F120C39B1A0C9@in.WebX.maYIadrTaRb...
> Charles,
up
> to the ? like this:
> - Tom
Message 9 of 9
Also, that article talks mostly about installations from CD< but there is a
link athe bottom of it that talks about shred CD drives. THere';s a
reasonably good chance that those particular registry keys are not exactly
what is needed in this case, BUT, it sounds similiar enought that I would go
to the MS KB to look for a solution.
> Charles,
up
> to the ? like this:
> - Tom
Administrator Productivity
