I had a similar error recently installing some totally different software.
That was done from CD< not over the network, but the problem turned out to
be a registry path issue. Try looking at this MS KB article
http://support.microsoft.com/support/kb/articles/Q221/5/24.ASP?LN=EN-US&SD=g
n&FR=0&qry=Q221524&rnk=1&src=DHCS_MSPSS_gn_SRCH&SPR=FP2000
(watch out for word wrap, it's a long URL, and don't mess with the registry
if you aren't willing to take the chance that you'fll have to reinstall your
entire operating system from scratch)
"Neil Sego" wrote in message
news:2F2D4E75C987F6B541542E0AA0FD19A7@in.WebX.maYIadrTaRb...
> Thanks Jason, but there is an ADT.msi in the IMAGE directory and still no
> success.
> "jason martin" wrote in message
> news:7A95F4B1B3878073A494FA015CBA639B@in.WebX.maYIadrTaRb...
> > Neil -
> > Make sure that there is a file in the image directory called ADT.msi.
> Also make sure that
> > it's size is 5,584,384 bytes (assuming that I have the correct build).
> This is a "Windows
> > Installer package". If it's not there you "might" be able to copy it
form
> the root of the
> > adt cd to the image folder (anyone know if this will actually work??)
> > jason martin
> > frankfurt-short-bruza
> > news:33B33D4795699E4E7A7AAF1E9C0FBE28@in.WebX.maYIadrTaRb...
> > > I have just setup ADT 3.3 on the FLEXlm. I am trying to install ADT
on
> the
> > > client work station. When I run the Setup.exe file I get an error
"This
> > > installation package could not be opened. Verify that the package
exists
> and
> > > that you can access it, or contact the application vendor to verify
that
> > > this is a valid Windows Installer package"
> > > If I go into the IMAGE directory and run the client.exe I can install
> but
> > > that is not a slient install.
> > > Help...
> > > Thanks
> > > Neil Sego
> > > nsego@schmidt-arch.com
