Installation & Licensing
Member
Ryokukitsune
Message 1 of 3 (339 Views)
Windows Easy Transfer tool broken licenses
339 Views, 2 Replies
12-19-2012 01:19 PM
I restored my computer using a backup made from the Windows Easy Transfer tool and I've run into a number of problems. in the case of Maya I can't seem to install it and get anything working; I can't even get the trial option to work. I know part of the problem is that this is new hardware, the second part I'm pretty sure is that there is leftover datat both transferred/missing that prevents Maya from registering correctly on my system.
After recovering the backup I was a bit surprised that the program didn't appear on the add/remove program list (W7 x64) and after trying the uninstaller in the Maya folder I got errors so I tried manually deleting the components of the program; deleting the Autodesk folder from both Program Files and Program Data and trying to do a "clean" install but afterwards I didn't even get the option to enter licensing information or accept a trial period. this licensing error pops up
[output window]
License problem in GUI mode launch dialog message
[dialog window]
License was not obtained
Tried Maya 2011 (657C1.2011.0.0.1), error 41
License method
environment variable MAYA_LICENSE_METHOD='standalone'
License file override
environment variable MAYA_ALT_EN is not set
The install trouble shooting process I've fallowed so far is to zero in on the problem so I've been concentrating on installing Maya only without the rest of the packages (backburner,composite,documentation server etc)
after each install I've checked my license.env file and its pretty consistant reading (copy/paste)
[license.env]
MAYA_LICENSE=unlimited
MAYA_LICENSE_METHOD=standalone
I'm considering doing another full format and using some lessons I learned from the process to prevent this problem (such as Windows Transfer tool disregards files/programs that are already installed) but I'd like to avoid that since I've already done the 5 hours of windows updates to get my system current.
can someone help me get this straightened out?
Ryo
TravisNave
Message 2 of 3 (335 Views)
Re: Windows Easy Transfer tool broken licenses
12-19-2012 01:59 PM in reply to: Ryokukitsune
You're probably going to have to search for the licensing and remove it manually.  It's likely in a ProgramData/Flexnet or ADLM hidden folder.  Image backups to dissimilar hardware will always break stand-alone licensing.  :smileysad:
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Member
Ryokukitsune
Message 3 of 3 (327 Views)
12-19-2012 03:21 PM in reply to: TravisNave
Honestly I knew that from the start. I did it a few weeks ago when I found out about the tool and had every intention of deactivating Maya before I committed to a format. Unfortunately I messed up my partition tables so bad I couldn't boot my computer so I decided to do an overdue upgrade so I could take advantage of DDR3 RAM and more than my previous 4 gigs, I digress though.
That fixed the issue. The licensing window came up after I did a reinstall. It's not giving me the option of using the 30 day trial but that’s cool, now I just have to update my student license to work on this build and everything should be golden.
Thanks for the quick response too!
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
