• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Member
    zyrebel
    Windows 8 pro 3ds Max issue
    872 Views, 5 Replies
    01-17-2013 06:18 PM
    I can not get any of the autodesk programs to run on my new laptop that runs windows 8. I got 3ds max to install but I can not do anything in the program. I downloaded 2012 and 2013 and if i try to open up a file it just fails to load.
    Any help would be great,
    specs:
    windows 8 pro
    Intel Core i7 3840QM Quad-Core 2.80GHz
    Single 2GB GDDR5 NVIDIA Quadro K3000M
    Please use plain text.
    *Expert Elite*
    DarrenP
    Re: Windows 8 pro 3ds Max issue
    01-17-2013 06:35 PM in reply to: zyrebel
    what do you mean you can't do anything?
    you need to be more specific
    Member
    zyrebel
    01-17-2013 06:45 PM in reply to: zyrebel
    I mean I can not move the screen, can not place objects the window is just there i can not import anything I got one thing to start to merge and it crashed.
    Product Support
    01-18-2013 11:56 AM in reply to: zyrebel
    zyrebel,
    Are you logged in with an admin account? Have you tried adjusting your graphics card settings? It sounds like a possible corrupt install. Have you tried removing, deleting residual folders and reinstalling? I would expect to find MAX folders here:
    C:\Program Files\Autodesk\
    C:\ProgramData\Autodesk\
    C:\Program Files (x86)\Autodesk\
    C:\Users\All Users\Autodesk\
    C:\Users\**YOUR USERID**\AppData\Roaming\Autodesk\
    C:\Users\**YOUR USERID**\AppData\Local\Autodesk\
    When installing, I would only install one program at a time in this case.
    Are you using any special interface devices? A special mouse, or 3d mouse or tablet? If so, I would uninstall. It may be worth checking the Windows Event Viewer as well to see if there is a listed module causing grief.
    Thank you for taking part in our community!
    David Dembkoski
    Product Support Specialist
    Autodesk Product Support
    Active Member
    01-23-2013 03:24 AM in reply to: zyrebel
    I have the same problem with AutoCAD Civil 3D 2013 (SP 1) on my notebook (HP EliteBook 8770w - with Windows 8 x64 and NVIDIA Quadro K3000m). When I use a Civil 3D command, the program crashes.
    I suspect a problem of driver of graphics card. I try with default driver (some commands work before the crash) and with last release of driver (the crash appears with the fist command). I don't find specific driver for AutoCAD on the NVIDIA website.
    For information, Civil 3D work fine in a virtual machine (Windows 7 x64) on my Windows 8 notebook!
    I hope about a solution ... in the near future...
    Best regards,
          philippe
    *Expert Elite*
    DarrenP
    01-23-2013 06:02 AM in reply to: p.germanier
    windows 8 isn't a supported OS for civil 3d 2013
