A.J. -
Your guess is actually very close. The autocad "save" procedure is something like this
(actually much more complicated than this, but...):
Check for the existence of a .bak file. If a .bak file exists delete it. Copy the
existing .dwg file to a .bak file. Delete the existing .dwg file. Save the current
drawing to the .dwg file.
If you don't allow users to delete items, autocad simply will not work. It is a required
permission. Delete inhibit actually doesn't do anything (good) anyway. If users can edit
the drawings and not delete them, they could simply open them, deleted everything in them
and save. Change rights are required.
If you are concerned about the data (as you should be) then a good backup program and some
redundancy in your server will do more for you than playing with the rights on that
server.
jason martin
frankfurt-short-bruza
"A.J." wrote in message
news:AE3F661ADDB16669E471F125506A27C4@in.WebX.maYIadrTaRb...
> Hello,
> I work for small drafting company for which I am the only IT person. Our
> large collection of drawing files is stored centrally on a Windows 2000
> Server, and worked on in-place by all the drafters. My boss would like to
> configure our server to prevent anyone but him from deleting these drawing
> files. Unfortunately, each time we turn off the Delete permission, we find
> that users can no longer save their files at all. Does anyone have any ideas
> on what is happening and how we can get around it? My best guess is that
> when AutoCAD saves, it actually makes a temp file, renames the original to
> something else, renames the temp file to what the original was, and then
> deletes the original, but any input/suggestions would be very much welcome.
> This problem is baffling us, and standing in the way of a major change to
> our company that we'd like to make.
