Okay, let's go back to the basics.
First check http://www.fsb-ae.com/acadnetwork/acadnetworkfaq.htm#2g
and make sure that you have adesksys.dll in the correct location.
Then check http://www.fsb-ae.com/acadnetwork/acadnetworkfaq.htm#2j and make sure that all that is working.
Then - Is the adlm in the same subnet as the clients???
You do have tcp/ip installed on the clients, right???
Your w95 stations can still get licenses from the adlm correct??? If you've fixed adesksys.dll then we need to look at other
differences between the w2k machines and the w95 machines.
jason
"sheffski" wrote in message news:f094260.1@WebX.maYIadrTaRb...
> Im running ACAD2000...
> any help appreciated
