I have solved my earlier problem with the ADESKSYS.DLL not working on W2K. I originally created a deployment folder which housed the client install files. The install worked fine on 95. Now every desktop in W2K Pro I copied the adesksys.dll into the client install directory on the server and renamed it to ADESKSYS.TCP (after renaming the original one to adesksys.tcpold).Once the install was ran on a client I added an environment variable ACADSERVER with a value of @servername (I only have one ADLM server).
Now all my W2K Pro clients pick up a license - problem solved....
I hope this helps anyone who had the problem of the adesksys.dll downloaded from the website. The readme file (sys_dll.txt) is vague....
sheffski
