Installation & Licensing
Why to specify a port number outside of the range 27000 through 27009 for lmgrd?
4 REPLIES 4
JTBWorld
428 Views, 4 Replies
I found this addition in the License Administration Guide for FlexNet 11.10.1. “Note • For security purposes, best practice is not to use a default port for the license server. Instead, specify a port number outside of the range 27000 through 27009.” Anyone know why? (Other than what is mentioned in this post Potential Security Vulnerability in FlexNet license manager, but should this not be fixed?)
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
Tags (2)
4 REPLIES 4
TravisNave
in reply to: JTBWorld
Jimmy,
If I had to speculate, I'd say that because the master daemon lmgrd is known to use ports 27000~27009, it becomes easier to locate the vulerability by testing known ports.  Whereas if you used a non default port, it may get overlooked.  Just my two cents...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
JTBWorld
in reply to: TravisNave
Yes, that was my thought also but on the other hand there are not that many ports anyway to test on as it would be automated.
Jimmy Bergmark
TravisNave
Yeah, I am not even sure that there are any cases of this even being exploited other than something they may have found internally.  I'm certainly not going to make a habit on making the NLM use a different port.
Autodesk Forums:
JTBWorld
I agree, I think the only good thing to do is to at least update the FlexNet exe files once in a while.
Jimmy Bergmark
Administrator Productivity
