Installation & Licensing
Why can't I plot my files to PDF?
1 REPLY 1
803 Views, 1 Reply
Hi, would like to know why i cannot plot my Revit Project Files to PDF when i am working. It only gives me the option to print to "FAX" or to print to "Microsoft XPS Document Writer".
Why is it doing this? Adobe Reader 9 that i have installed on my Toshiba laptop works fine all the time when i am plotting from AutoCAD, but when i attempt this in Revit I do not get "PDF" as an option.
Other in the studio can do this fine, and i would like to be the same as plotting to PDF is import so can be imported to Photoshop, etc.
Regards Joseph Mazza
joemazza1992@gmail.com
Tags (4)
1 REPLY 1
Revit is not like AutoCAD.
If you  want make a .PDF from Revit you must install a soft like PDF CREATOR to do it.
Then use the print option to make your PDF.
Administrator Productivity
