Hi, would like to know why i cannot plot my Revit Project Files to PDF when i am working. It only gives me the option to print to "FAX" or to print to "Microsoft XPS Document Writer".
Why is it doing this? Adobe Reader 9 that i have installed on my Toshiba laptop works fine all the time when i am plotting from AutoCAD, but when i attempt this in Revit I do not get "PDF" as an option.
Other in the studio can do this fine, and i would like to be the same as plotting to PDF is import so can be imported to Photoshop, etc.
Regards Joseph Mazza
Revit is not like AutoCAD.
If you want make a .PDF from Revit you must install a soft like PDF CREATOR to do it.
Then use the print option to make your PDF.
