Installation & Licensing
Who locked this file?????
5 REPLIES 5
276 Views, 5 Replies
To anyone
I have several DLL files that I wrote to function inside AutoCAD but have a
network related problem. Does anyone know of anyway besides the NT server
manager to find out who (or is it whom?) has a DLL file locked (loaded) so I
can get them out of it and place an updated file on the server? I have
looked for some utility that will give me at least a hint of which machine
is the culprit (we have many users that walk away with CAD still running and
when I say all users exit they aren't there to) but nothing that can tell me
which user or machine has the file locked. Now I load up server manager and
have to go through several thousand files to find the exact one that is
causing the problem!
AHGA
Shawn
5 REPLIES 5
In article , romkeys@NOSPAMnbnet.nb.ca
says...
> To anyone
> AHGA
> Shawn
Hi, Windows Commander, which is a superior filehandling utility, can do this.
A shareware version without functionality- /time-limits can be downloaded from www.ghisler.com
In WC you have to access the hidden commandset which is huge. You can du that through menu:
Configuration - Button Bar - Command. Here you have to choose a toolbutton that activates the
command: cm_ShowFileUser
And besides WC can do so much more, so take a look.
Best regards
Lars Sandberg
TechSolution
dba IMAGINiT Technologies
Hi Shawn,
Thanks for bringing this up again... I knew there had to be a good tool to
accomplish this, and I finally found it.
Check out "PSFILE" which is a part of SysInternal's freeware "PsTools" kit:
http://www.sysinternals.com/ntw2k/freeware/pstools.shtml
Here is the command line usage:
PsFile lists or closes files opened remotely.
Usage: psfile [\\RemoteComputer [-u Username [-p Password]]] [[Id | path]
[-c]]
-u Specifies optional user name for login to
remote computer.
-p Specifies password for user name.
Id Id of file to print information for or close.
Path Full or partial path of files to match.
-c Closes file identified by file Id.
Omitting a file identifier has PsFile list all files opened remotely.
And here is an example of files in use:
PsFile v1.01 - local and remote network file lister
Copyright (C) 2001 Mark Russinovich
Sysinternals - www.sysinternals.com
Files opened remotely on SOMEPC:
[38] E:\transfer\1230-DA-001.dwg
User: SOMEUSER
Locks: 0
Access: Read Write
[90] E:\transfer
User: SOMEUSER
Locks: 0
Access: Read
[159] E:\transfer\us_dk2ptr_6.exe
User: SOMUSER
Locks: 0
Access: Read
It even lets you close specific files!
Let me know if this works for you.
Chris
"Shawn Romkeys" wrote in message
news:E095D22486B5E1471AFC47B55095E6CE@in.WebX.maYIadrTaRb...
> To anyone
a
I
and
me
and
> AHGA
> Shawn
Lars
Thanks for the location! It works but is there a way to remotely check what
files are locked on the server and by whom. In order to find this I need to
install WC on the server and then it will tell me who has it locked. I
would like to be able to list it remotely from my system?
It does work and is saving me a lot of time, just looking for a little more
info!
TFTH
Shawn
; "TechSolution dba IMAGINiT Technologies"
wrote in message news:MPG.172b5486e001e0be9896d5@discussion.autodesk.com...
> In article ,
> says...
> > To anyone
have a
server
so I
machine
and
tell me
and
> > AHGA
> > Shawn
this.
that through menu:
that activates the
> Best regards
> Lars Sandberg
> TechSolution
Chris
That does exactly what I was looking for!
Thanks for the help!
Shawn
"Chris Dodge [Americas Product Support]"
wrote in message
news:B39EE7AFB60A2D2A6E81280ED14BE950@in.WebX.maYIadrTaRb...
> Hi Shawn,
kit:
> [-c]]
> remote computer.
> User: SOMEUSER
> Locks: 0
> Access: Read Write
> [90] E:\transfer
> User: SOMEUSER
> Locks: 0
> Access: Read
> User: SOMUSER
> Locks: 0
> Access: Read
> Chris
> > To anyone
have
> a
server
so
> I
machine
> and
tell
> me
> and
> > AHGA
> > Shawn
In W2000 server you have the possibility to remotely administer your server.
The other solution is to use VNC (freeware).
http://www.uk.research.att.com/vnc/download.html
Best regards
Franck Hervet
Responsable Informatique
Aricad
ZA de l'observatoire
4 avenue des trois peuples
78180 Montigny le bretonneux
Tel : 0139441818
Fax : 0130575885
http://www.aricad.fr
"Shawn Romkey" a écrit dans le message news:
E94EF28924BCD961CA30E76DA494C41E@in.WebX.maYIadrTaRb...
> Lars
what
to
more
> info!
> TFTH
> Shawn
> wrote in message
> > In article ,
> > says...
> > > To anyone
> have a
> server
(loaded)
> so I
> machine
running
> and
> tell me
manager
> and
is
> > > AHGA
> > > Shawn
> this.
downloaded
> that through menu:
toolbutton
> that activates the
> > Best regards
> > Lars Sandberg
> > TechSolution
Administrator Productivity
