In W2000 server you have the possibility to remotely administer your server.
The other solution is to use VNC (freeware).
http://www.uk.research.att.com/vnc/download.html
Best regards
Franck Hervet
Responsable Informatique
Aricad
ZA de l'observatoire
4 avenue des trois peuples
78180 Montigny le bretonneux
Tel : 0139441818
Fax : 0130575885
http://www.aricad.fr
"Shawn Romkey" a écrit dans le message news:
E94EF28924BCD961CA30E76DA494C41E@in.WebX.maYIadrTaRb...
> Lars
> Thanks for the location! It works but is there a way to remotely check
what
> files are locked on the server and by whom. In order to find this I need
to
> install WC on the server and then it will tell me who has it locked. I
> would like to be able to list it remotely from my system?
> It does work and is saving me a lot of time, just looking for a little
more
> info!
> TFTH
> Shawn
> ; "TechSolution dba IMAGINiT Technologies"
> wrote in message
news:MPG.172b5486e001e0be9896d5@discussion.autodesk.com...
> > In article ,
> romkeys@NOSPAMnbnet.nb.ca
> > says...
> > > To anyone
> > > I have several DLL files that I wrote to function inside AutoCAD but
> have a
> > > network related problem. Does anyone know of anyway besides the NT
> server
> > > manager to find out who (or is it whom?) has a DLL file locked
(loaded)
> so I
> > > can get them out of it and place an updated file on the server? I have
> > > looked for some utility that will give me at least a hint of which
> machine
> > > is the culprit (we have many users that walk away with CAD still
running
> and
> > > when I say all users exit they aren't there to) but nothing that can
> tell me
> > > which user or machine has the file locked. Now I load up server
manager
> and
> > > have to go through several thousand files to find the exact one that
is
> > > causing the problem!
> > > AHGA
> > > Shawn
> > Hi, Windows Commander, which is a superior filehandling utility, can do
> this.
> > A shareware version without functionality- /time-limits can be
downloaded
> from www.ghisler.com
> > In WC you have to access the hidden commandset which is huge. You can du
> that through menu:
> > Configuration - Button Bar - Command. Here you have to choose a
toolbutton
> that activates the
> > command: cm_ShowFileUser
> > And besides WC can do so much more, so take a look.
> > Best regards
> > Lars Sandberg
> > TechSolution
