Installation & Licensing
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Who is using the AutoDesk Design 2012 licenses?
- Highlight
- Email to a Friend
At YMMC we use AutoDesk Design Premium 2012. We currently have 4 network license seats. Is there a way to find out which users are using the licenses at any given time.
Re: Who is using the AutoDesk Design 2012 licenses?
- Highlight
- Email to a Friend
Open LMTOOLS and do a Status Enquiry from the Server Status tab. It will tell you exactly who is using the licenses.
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: Who is using the AutoDesk Design 2012 licenses?
- Highlight
- Email to a Friend
You can also use our freeware JTB FlexReport LT that makes it easy to get a HTML-report over all current users. The program can be distributed to all your users if you like so they themselves can also check this.
JTB World - Software development and consulting
Specialities: AutoCAD, AutoCAD Architecture and Revit
http://www.jtbworld.com
JTB FlexReport - network license reports
http://www.jtbworld.com/jtbflexreport/index.htm
- Highlight
- Email to a Friend
When I run LMTools I get this problem:
[Detecting lmgrd processes...]
Error getting status: Cannot find license file.
The license files (or license server system network addresses) attempted are
listed below. Use LM_LICENSE_FILE to use a different license file,
or contact your software provider for a license file.
Filename: C:\Documents and Settings\All Users\Application Data\Software Toolbox\common\License\*.lic
License path: C:\Documents and Settings\All Users\Application Data\Software Toolbox\common\License\*.lic;
FLEXnet Licensing error:-1,359. System Error: 2 "No such file or directory"
For further information, refer to the FLEXnet Licensing documentation,
available at "www.flexerasoftware.com".
- Highlight
- Email to a Friend
It appears that your LMTOOLS is looking for another 3rd party license instead of Autodesk. Try setting an environment variable for this.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?si
I had to do this yesterday for a client as well and use LM_LICENSE_FILE variable as well; created the same as the ADSKFLEX_LICENSE_FILE in the link above. Good luck!
- Highlight
- Email to a Friend
I was trying to use the LMTool program on the License server and could not get it to work. Then I placed a LMTools shortcut on my PC entered the Enviromental variables that you gave me set the path for the License file and everything started working.
Thanks for the help, Guru
- Highlight
- Email to a Friend
Excellent! Thanks for the follow-up!
