• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Member
    Accepted Solution
    Who is using the AutoDesk Design 2012 licenses?
    264 Views, 6 Replies
    10-04-2012 11:53 AM
    At YMMC we use AutoDesk Design Premium 2012. We currently have 4 network license seats.  Is there a way to find out which users are using the licenses at any given time.
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: Who is using the AutoDesk Design 2012 licenses?
    10-04-2012 01:03 PM in reply to: YmmcAuto
    Open LMTOOLS and do a Status Enquiry from the Server Status tab.  It will tell you exactly who is using the licenses.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    10-05-2012 05:39 AM in reply to: YmmcAuto
    You can also use our freeware JTB FlexReport LT that makes it easy to get a HTML-report over all current users. The program can be distributed to all your users if you like so they themselves can also check this.
    Jimmy Bergmark
    JTB World - Software development and consulting
    Specialities: AutoCAD, AutoCAD Architecture and Revit
    http://www.jtbworld.com
    JTB FlexReport - network license reports
    http://www.jtbworld.com/jtbflexreport/index.htm
    Member
    10-05-2012 01:23 PM in reply to: YmmcAuto
    When I run LMTools I get this problem:
    [Detecting lmgrd processes...]
    Error getting status: Cannot find license file.
     The license files (or license server system network addresses) attempted are
    listed below.  Use LM_LICENSE_FILE to use a different license file,
     or contact your software provider for a license file.
    Filename:      C:\Documents and Settings\All Users\Application Data\Software Toolbox\common\License\*.lic
    License path:  C:\Documents and Settings\All Users\Application Data\Software Toolbox\common\License\*.lic;
    FLEXnet Licensing error:-1,359.  System Error: 2 "No such file or directory"
    For further information, refer to the FLEXnet Licensing documentation,
    available at "www.flexerasoftware.com".
    *Expert Elite*
    TravisNave
    10-05-2012 01:33 PM in reply to: YmmcAuto
    It appears that your LMTOOLS is looking for another 3rd party license instead of Autodesk.  Try setting an environment variable for this.
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=8385605&linkID=9240617
    I had to do this yesterday for a client as well and use LM_LICENSE_FILE variable as well; created the same as the ADSKFLEX_LICENSE_FILE in the link above.  Good luck!
    Travis Nave
    Member
    10-10-2012 10:48 AM in reply to: YmmcAuto
    I was trying to use the LMTool program on the License server and could not get it to work.  Then I placed a LMTools shortcut on my PC entered the Enviromental variables that you gave me set the path for the License file and everything started working.
    Thanks for the help, Guru
    *Expert Elite*
    TravisNave
    10-10-2012 12:01 PM in reply to: YmmcAuto
    Excellent!  Thanks for the follow-up!
    Travis Nave
