Installation & Licensing
What registry key to remove to make setup to reinstall RSA 2013
3 REPLIES 3
Priitl220
1679 Views, 3 Replies
Something went wrong with installation of Autodesk Edu Master Suite 2013. It shows  that RSA is installed but its is not as setup failed.
Need to reinstall but it is not found in windows uninstall dialogbox. And when starting setup it is shown as installed.
So i should delete some registry key so the setup would not see RSA anymore?
I deleted structural form HKCU and HKLM unders autodesk.
It did not help?
____________________________________________
If you find my post useful give me Kudos. Thank you!
If my post solved your problem, accept it as a solution.
3 REPLIES 3
TravisNave
in reply to: Priitl220
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
For all other installation problems consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Priitl220
in reply to: TravisNave
The first tool did the trick. It just took about a day. It seems like it freezes but you just have to leave it alone.
TravisNave
Thanks for the confirmation.  I've had mixed reviews on that new Microsoft tool.  I've always reverted to the MSI Cleanup utility as a last resort, but it is no longer supported.
Autodesk Forums:
Administrator Productivity
