Something went wrong with installation of Autodesk Edu Master Suite 2013. It shows that RSA is installed but its is not as setup failed.
Need to reinstall but it is not found in windows uninstall dialogbox. And when starting setup it is shown as installed.
So i should delete some registry key so the setup would not see RSA anymore?
I deleted structural form HKCU and HKLM unders autodesk.
It did not help?
Solved by TravisNave. Go to Solution.
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
For all other installation problems consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
The first tool did the trick. It just took about a day. It seems like it freezes but you just have to leave it alone.
Thanks for the confirmation. I've had mixed reviews on that new Microsoft tool. I've always reverted to the MSI Cleanup utility as a last resort, but it is no longer supported.
