Jason,
The vendor string is showing the usage type. i.e commercial/nfr/educational
and whether or not the license is temporary or not.
Simon Gillis
Analyst
DPG Product Support EMEA
Autodesk WW Support & Services
"jason martin" wrote in message
news:F8C3FF5BD1F6A8242D1C5A15719433B4@in.WebX.maYIadrTaRb...
> James -
> The .lic file should be something like the following.
> SERVER pc12345 123456789012
> USE_SERVER
> VENDOR adskflex port=2080
> INCREMENT 41100ACD_2002_0F adskflex 1.000 permanent 3 \
> VENDOR_STRING=commercial:permanent SUPERSEDE DUP_GROUP=H \
> ISSUED=22-jan-2001 ck=231 SN=399-99999999 SIGN=6E88EFA8D44C
> Where the first line is
> SERVER The name of your adlm server : the ethernet address of your server
> USE_SERVER just has to be there??
> VENDOR the name of the vendor daemon : the port the vendor daemon runs on
(by default)
> INCREMENT the secret squirrel name of the product : The vendor daemon name
again : The
> vendor daemon version : the date the license expires : the number of
licenses \
> VENDOR_STRING=commercial:permanent (I really don't understand this part,
maybe Simon will
> explain) : SUPERSEDE means that this line supersedes any lines with the
same increment
> code issued at an earlier date : DUP_GROUP=H (host mode) means to only use
one license
> when a single workstation opens up more than one session of the product \
> ISSUED=The date it was issued : ck=some kind of check sum. I'm not sure
what. SN=Acad
> serial number SIGN=Secret squirrel code generated so that people can't
just make up
> license files themselves.
> The \ at the end of each line appear to be "continued" statement so that
the lines can be
> "wrapped".
> If you have more than 1 product (say vanilla and ldt) then you'll have an
INCREMENT....
> line for each product with a different product number ck# SN and Sign #.
> hth
> jason martin
> frankfurt-short-bruza
> "James Wedding" wrote in message
> news:5188FC24C27C27BC3DE672B3ACAA01A2@in.WebX.maYIadrTaRb...
> > I got my nice e-mail from Autodesk with a whole bunch of stuff in it.
What
> > portion of this e-mail do I need to cut and paste into the .lic file
that I
> > point my FlexLM install to?
> > James Wedding
> > Jones & Boyd, Inc.
> > Dallas, Texas
> > jwedding@NOPSPAMjones-boyd.com
> > REMOVE NOSPAM FOR REPLY
