Installation & Licensing
*Woynowskie, Kim M.
Message 1 of 4 (60 Views)
What makes drawings detach so slow
60 Views, 3 Replies
09-23-2000 12:44 PM
I am using A2Ki map, on a Novell network with 100MB/sec NIC with
certified cableling. The computer in use is a 300Mhz Pentium II with
256M ram.
My problem is that it takes about 5 minutes to disconnect an attached
drawing file (about 5 to 10 M in size) This makes it extremely
frustating during the day when working with multiple drawings. It seems
as though all I'm doing is waiting for these diffent drawings to finish
detaching. I have also tried this an another computer that is a 550Mhz
and it has the same problem. All these computers are running with
AutoCAD map installed on the local machine and NOT on the Netware
server.
*Hurley, Shaan
Message 2 of 4 (60 Views)
Re: What makes drawings detach so slow
09-24-2000 10:51 AM in reply to: *Woynowskie, Kim M.
Kim,
Where do the files you are working on reside, on the network or local? If
they are on the network if you move them local and run disconnected from the
network do you still see the delay? I suspect the network and if removed you
will see the problem does not occur.
Sincerely,
Shaan Hurley
Autodesk Beta Programs
"Kim M. Woynowskie" wrote in message
news:39CD0814.151652F3@ci.grandjct.co.us...
> 256M ram.
> server.
*Woynowskie, Kim M.
Message 3 of 4 (60 Views)
Re:
09-25-2000 08:53 AM in reply to: *Woynowskie, Kim M.
The files reside on the Network. Also they did not used to be this slow. We
recently moved our office and upgraded all of our network components and it
seems every since we went to "faster" network componenets everything went
slower.
Shaan Hurley wrote:
> Kim,
> Sincerely,
> Shaan Hurley
> > 256M ram.
> > server.
*Hurley, Shaan
Message 4 of 4 (60 Views)
Re:
09-25-2000 07:03 PM in reply to: *Woynowskie, Kim M.
Kim,
It sure sounds like a network issue. Have your administrator take a look.
You did not say if the problems occur as well when the network is out of the
equation, but I would suspect the problem goes away. Also your recent move
may have something to do with it.
Sincerely,
Shaan Hurley
http://betaprograms.autodesk.com
news:39CF74EE.3D95B1C9@ci.grandjct.co.us...
We
it
> slower.
> Shaan Hurley wrote:
> > Kim,
If
the
you
> > Sincerely,
> > Shaan Hurley
> > > 256M ram.
seems
finish
550Mhz
> > > server.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
