I am trying to run Microsoft Fix It to uninstall a partially installed Autodesk Revit. I need to know th product code to do so. What is the product code (registry) of Autodesk Revit 2013?
Solved by ukdxb012. Go to Solution.
Same problem here. Have you solved? I somehow failed to install Revit 2013 and now it doesn't start, it doesn't uninstall and it's not possible to install a new one becouse the system said it's already installed. Tried Fix-it from Microsoft: the first time it said it solved the problem, but it didn't. A second time, Revit is no longer on Fix-it list and to make the program work I have to enter the "product code", which after long research I can't find. Any help?
Hi, hopefully this link will help you both out 🙂
