What does 85674T1MF_2011_0F stands for?
I need to know which product my user is dealing with, but I am not able to identify it on the forhums or quick documentation search.
Thank you.
Solved by AnkushVed. Go to Solution.
DarrenP
DarrenP
T1MF license is Term Multi Flex license. It will allow running multiple 2011 Autodesk products (around 100). It is mentioned in 2012 feature codes kb article, but probably got missed from adding in the 2011 feature codes document.
Hi Ankush, I flagged your post as a solution
I'm checking with our contents team to update our technical solutions.
Thank you for your answer 🙂
Looking fordward to see the documentation updated.
Thanks.
