Installation & Licensing
WSCommCntr3.exe Prevents AutoCAD Start-up
3 REPLIES 3
jcroker
8085 Views, 3 Replies
I just installed AutoCAD 2012 and AutoCAD Architecture 2012 upgrades on our workstations in the office. Stand alone installs. Everything works fine on one workstation, but on the second under one users log-on - both acad and acad arch lock-up on start-up. I discovered if with win taskmanager i stop the process "WSCommCntr3.exe" both acad and acad arch (acad for brevity) will continue and start up fine. But, close and start again, I have to stop "WSCommCntr3.exe" again before acad will start. If i log on to the same machine, there is no problem. I thought maybe it was my admin priv, but when I assigned admin priv to the other user it had no effect. It appears to me there is something in his user account that is causing the problem. But it is beyond my windows knowledge base I guess. I had a similar problemon with same user and acad 2011 and i just turned off communication center (i believe) as a quick fix and never revisited.
Although I can work around the workstation well enough, I know little about the network, that is IT's domain. we do have continuous access to the internet through the network.
Does anyone have a suggestion as to what it might be?  I would like to tell my IT department what to changeor look at  in the users log on profile so this can be resolved.
any help would be appreciated
fyi - workstations identical - win xp pro 64, dell T7400
3 REPLIES 3
hashim.mundol
in reply to: jcroker
If you have a proxy server for internet connection, you might see similar issues, IT could be able to help you bypass the connection issue.
If not
Please re-create windows profile for the affected users
Or
rename WSCommCntr3.exe to avoid the error (just another work around)
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
andylaug
useless response!
ANDREWLIGHT
in reply to: andylaug
/\ +1
Administrator Productivity
