• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Member
    WHY MUST AutoCAD install .NET?????????????????
    206 Views, 3 Replies
    11-29-2012 04:18 PM
    2012/11/22:12:23:26                Installing .NET Framework Runtime 4.0 Language Pack: G:\Software\autocad 2013\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe /q
    2012/11/22:12:23:34                Install        .NET Framework Runtime 4.0 Language Pack        Failed        Installation aborted, Result=1603
    Why!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    RESOLVE IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    DRIVE ME CRAZY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Edited by
    Discussion_Admin
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: WHY MUST AutoCAD install .NET?????????????????
    11-30-2012 08:23 AM in reply to: wongbean
    Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
    .NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
    http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
    Good Luck!
    Edited by
    Discussion_Admin
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Member
    12-01-2012 08:55 PM in reply to: TravisNave
    I HAVE DONE EVERTHING I CAN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    STILL CANNOT INSTALL IT !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    WHAT STUPID SOFTWARE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    *Expert Elite*
    TravisNave
    12-03-2012 01:58 PM in reply to: wongbean
    Relax.  The software is fine.  It's your operating system that has the problem.  Why don't you try to install the full version of .NET Framework manually from Microsoft and see if you can get it to install first.
    Travis Nave
