• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Valued Contributor
    skatterbrainz
    Virtual Hosting of FlexLM / LMTOOLS
    881 Views, 4 Replies
    05-16-2012 05:59 AM
    I see in the documentation for Map 3D 2013 that the only "Virtual Machine Support" shown is for "VMware ESX 3.5" on "Intel PC 64".  Does this mean Autodesk does NOT support Microsoft Hyper-V on Windows Server 2008 R2 ?  Just making sure before we build a new license server for our environment.  The virtualization platform at this client is Hyper-V only.
    Get the Visual LISP Developer's Bible 2011 Edition, and the AutoCAD Network Administrator's Bible 2012 Edition on Amazon Kindle
    Please use plain text.
    TravisNave
    Re: Virtual Hosting of FlexLM / LMTOOLS
    05-16-2012 07:13 AM in reply to: skatterbrainz
    The NLM will run fine on a virtual machine.  Just make sure you hard code the MAC address as virtual machines have a tendency to change for no good reason, thus invalidating your license file.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Valued Contributor
    skatterbrainz
    05-16-2012 07:35 AM in reply to: TravisNave
    I figured as much.  I don't doubt it would run reliably, but I have to verify if it is officially "supported" by Autodesk.  The customer I am working for insists it is vendor supported.
    TravisNave
    05-16-2012 07:58 AM in reply to: skatterbrainz
    It is officially supported by Flexera, the publisher of the license manager.  Autodesk simply licenses the technology, along with many other 3rd party vendors.
    Check out Chapter 15 of the user guide:
    http://www.globes.com/support/utilities/fnp_LicAdmin_11_10_1.pdf
    Travis Nave
    Valued Contributor
    skatterbrainz
    05-16-2012 08:45 AM in reply to: TravisNave
    Thank you!  I appreciate the help.
