Installation & Licensing
E_Hayes
175 Views, 1 Reply
Video card
Can a Sapphire HD 7950 properly run Autodesk ECS ultimate 2014?
1 REPLY 1
TravisNave
in reply to: E_Hayes
Here are the certified cards:
http://usa.autodesk.com/adsk/servlet/syscert?siteID=123112&id=18844534&results=1&stype=graphic&suite...
But so long as your card meets or exceeds the minimum requirements, you can probably get by.
http://images.autodesk.com/adsk/files/entertainement_creation_suite_2014.pdf
I suspect you will be fine.  I run the ECS on a much lower end card without issues.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
