Installation & Licensing
Vault 2012 installation is failiing. Please assist.
4 REPLIES 4
255 Views, 4 Replies
Local installation under an admin user for Vault 2012 is silently failing. Attached is a log file. Does anyone have any suggestions? If further information is needed please ask and I will supply as best/fast as possible.
4 REPLIES 4
TravisNave
Copy the installation to your hard drive and install from there as Admin and with UAC and anti-virus off.  If you're doing a silent install, don't.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
Thank you. I will try that and get back to you and let you know my progress.
I am still receiving the same error. The installation is stored locally, I am logged in as the domain admin and the OS is XP. any suggestions?
TravisNave
Was the installation a deployment?  Or did you copy the physical media to the local hard disk?  You'll need to forget the deployment and copy the DVD or USB drive to C:\ and run setup there.  Post your install logs from %TEMP% if it fails again.
Autodesk Forums:
Administrator Productivity
