Installation & Licensing
495 Views, 4 Replies
Vault 2012 Prof
After install and activating the FlexLM license, VP 2012 still can't get a license.
Error: "Failed to acqurie a license." (Not really many information...)
LMTools V 11.9.1
LmGrd V 11.9.1
Status Enquiry: Total of 30 licenses issued;  Total of 0 licenses in use
So why can't get the VP a license?
Where to search?
Thx
René
4 REPLIES 4
DarrenP
try these: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13107015&linkID=9261340
DarrenP
TravisNave
With Vault, it's most likely a IPv6 issue.  If you come up empty with the link above, make a change to your hosts file under C:\Windows\system32\drivers\etc and add the servername to the IPv4 address.  That has fixed the similar issue for me in house.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Thx the license.lic trick d it.
It would be very helpful, if this link not only in the install progress is available, also in the error box or the vault manuals.
TravisNave
The NLM is a 3rd party product, so additonal troubleshooting support in the manuals is unlikely.  At least you have the discussion forums for help!
Autodesk Forums:
Administrator Productivity
