We are currently attempting to upgrade from Autodesk Inventor/Vault 2009 to 2011. We have a dedicated server that we have installed Vault on for a few years with each upgrade. For some reason when the server was set up, it was partitioned to have 12 GB on C:, and over 300 GB on D:. 2011 finally has "broken the bank" and requires more space than we have available. It claims it needs over 9 total GB to install on our server. Here's my question.
When I attempt to install the new Vault, it always defaults to using the existing AUTODESKVAULT SQL database. I am not a SQL pro, but I have no idea how to allow me to install this information on the 😧 drive. I have already used the ADMS to detach, migrate, and reattach the vault and all content libraries to the 😧 drive.
I read through http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=5723934&linkID=9261340 which is dated 2007, but doesn't refer to the newer Vault installations. It involved changing the setup.ini file to point to a different drive entirely, and therefore creating a "new" local AUTODESKVAULT SQL instance.
The only option I really have right now is to somehow have everything involving the 2011 Vault installed on the 😧 drive.
Any suggestions? Thanks!
Edited by: gradys on May 12, 2010 1:36 PM
