Installation & Licensing
Member
roynorton5632
Message 1 of 10 (266 Views)
VAULT 2014 AND INVENTOR 2012
266 Views, 9 Replies
03-13-2014 03:35 AM
Hi all, first post so please be gentle.
I've been tasked with installng and configuring Vault for use with Inventor at first. Now I've done some reading and remain confused but I'm hoping that will change soon.
We have access to Vault 2014 Pro and all of the previous releases and the project will be modelled using Inventor 2012.  My first question is are the two compatible or will I need to install Vault 2012?
heading back to my reading and research now....
Thanks in advance.
Distinguished Mentor
JoAnn_Hogan
Message 2 of 10 (260 Views)
Re: VAULT 2014 AND INVENTOR 2012
03-13-2014 03:59 AM in reply to: roynorton5632
No need to change to Vault 2012. Inventor 2012 would be able to connect to Vault 2014
Please let me know if this helps
Jo (P.S follow me on twitter @JoAnn_Hogan)
If this post solved your issue please mark as solved and Kudos are always welcome =)
AutoCAD Certified Professional 2014 / Inventor Certified Professional 2014
Member
roynorton5632
Message 3 of 10 (257 Views)
03-13-2014 04:01 AM in reply to: JoAnn_Hogan
Thanks for the quick reply Vault 2014 it is then! Heading to search for an installation guide now.
JoAnn_Hogan
Message 4 of 10 (250 Views)
03-13-2014 04:12 AM in reply to: roynorton5632
I would stongly recommend that you get your closet VAR to do the implementation for you as they have to customize and set it up according to your needs. They will also test to make sure everything works and transfer your data for you.
And here is the getting started guide as well: http://knowledge.autodesk.com/support/vault-products/getting-started#?rows=10&sort=score
Member
roynorton5632
Message 5 of 10 (242 Views)
03-13-2014 04:21 AM in reply to: JoAnn_Hogan
sadly our contract is directly with Autodesk not a VAR, and the relationship is sensitive at best at present so that's not an option I have.
Thanks for the getting started guide and any info, tips or tricks are very gratefully received as I'm entirely on my own with his one.
JoAnn_Hogan
Message 6 of 10 (233 Views)
03-13-2014 04:46 AM in reply to: roynorton5632
Glad I could help a little bit. Good luck with this
Member
roynorton5632
Message 7 of 10 (231 Views)
03-13-2014 04:50 AM in reply to: JoAnn_Hogan
Last question for you. Is SQL included as part of ADMS/File Server install or is that a separate requirement? Also SQL 2008 or 2012?
Done now :-)
JoAnn_Hogan
Message 8 of 10 (222 Views)
03-13-2014 05:08 AM in reply to: roynorton5632
Yes, SQL is included but it is the express version 2008. When you the ADMS it will automatically install SQL express for you.
Member
roynorton5632
Message 9 of 10 (192 Views)
03-14-2014 04:09 AM in reply to: JoAnn_Hogan
Fantastic, we have progress. I have Vault installed, EDMS working, Client working, not I need to get some files in there and configure the applications. Very much appreciate the help :smileyhappy:
JoAnn_Hogan
Message 10 of 10 (188 Views)
03-14-2014 04:19 AM in reply to: roynorton5632
Glad it is working now and I could be of help.
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
