I need to move our two main network license mangager apps over from old to new machines. We use the adskflex_license_file variable to point client machines to two distributed license servers. My plan was to use scripting to change everyone's variable values over to the new server names. However, someone suggested that I could simply redirect the licensing traffic with DNS using CNAME. This would redirect all pointers from the old name to the new name.
Has anyone tried this? Will this work?
Solved by Jroper. Go to Solution.
Just wanted to follow up. If anyone has this question, the answer is yes. We have set our adskflex_license_file to autodesklicense01;autodesklicense02;autodesklicense03. We can now redirect those aliased names to whatever hosts we like now. Very useful when migrating data centers. We had to move our license vm's to another place and needed to change hosts and naming convention. Now, we can move anywhere without distrupting or pushing out a new variable to clients. The other benefit is no one has to wonder where the autodesk license servers are. You can use remote desktop or explore using the cname without knowing what the real host name is.
