Installation & Licensing
Using AutoCAD if WAN link is down
3 REPLIES 3
colmag
248 Views, 3 Replies
If you have a distributed license server setup, but for some reason an office can't access the WAN (even with a redundant connection this occasionally happens) is there any way for that office to be able to use AutoCAD whilst waiting for the network connection to be restored?
3 REPLIES 3
in reply to: colmag
Include a local server as part of the distribution?
wrote in message news:5803594@discussion.autodesk.com...
in reply to: colmag
This works very well.... Prority set the var in regsitry (sys var) with
policies or something to fail over to site to site to site. Your local site
will be priority (the first one). This is mainly for a local server
failure, but can also prevent your issue from arrising.
Ricky
Houston
"Drew Burgasser" wrote in message
news:5804148@discussion.autodesk.com...
TravisNave
in reply to: colmag
For training purposes, it is required that the offices on our WAN to borrow licenses to prevent down-time as a result of this unforseen problem.
Autodesk Forums:
Administrator Productivity
