Installation & Licensing
*Nehls, Kevin
Message 11 of 25 (131 Views)
Re:
01-11-2001 12:10 AM in reply to: *Heiman, Miky
But everything you need IS documented. Mike already read the article that
has ALL of the information that he needs.
Please re-read the article TS55765 on the Knowledge Base. It tells you
*exactly* what registry keys *and* which directories need to have their
permissions opened up so that a USER can use AutoCAD.
Kevin Nehls
remove -ns- for direct reply
"jason martin" wrote in message
news:6C5191632F703A08D304B67BE015B2A6@in.WebX.SaUCah8kaAW...
> I agree. This should be documented somewhere by autodesk. Some companies
have a security
> policy that does not allow the users to have the control required by
autocad.
(snip)
*martin, jason
Message 12 of 25 (131 Views)
Re:
01-11-2001 02:10 AM in reply to: *Heiman, Miky
Kevin et al
My apologies. I had missed TS55765.
sorry
jason martin
frankfurt-short-bruza
"Kevin Nehls" wrote in message
news:F811196DBB9C30D6BF46C8740806FC7A@in.WebX.SaUCah8kaAW...
> Kevin Nehls
*Nehls, Kevin
Message 13 of 25 (131 Views)
Re:
01-11-2001 02:41 AM in reply to: *Heiman, Miky
No apologies necessary from you. Mike keeps posting that he is having
problems with this. Now why would you state that you read an article that
you obviously did not read? (question not intended to you Jason)
MIKE, please read the TS55765 article again!!! Yes it is talking about
performing this with group policies and Windows 2000 domain controllers, but
it DOES tell you the registry key and the directory that you need to open
permissions up.
BTW, I already posted exactly what you need to do just from reading the
article myself.
Kevin Nehls
news:2182E9B5AB63B3B54EC86A3C147C2784@in.WebX.SaUCah8kaAW...
> Kevin et al
> sorry
> jason martin
*martin, jason
Message 14 of 25 (131 Views)
Re:
01-11-2001 02:52 AM in reply to: *Heiman, Miky
I saw the info in your post and liked it. I just hadn't seen this in the kb.
Thanks for the information Kevin.
news:67C1823BA2CE6596D43BE8C077357743@in.WebX.SaUCah8kaAW...
(snip)
> article myself.
> Kevin Nehls
*McCully, Jeremy
Message 15 of 25 (131 Views)
Re:
01-28-2001 10:47 PM in reply to: *Heiman, Miky
TS55765 ??
Where is it? Has Autodesk removed it? I can't find it in the knowledge
base..
Jeremy
> Kevin Nehls
companies
> have a security
> autocad.
> (snip)
*martin, jason
Message 16 of 25 (131 Views)
Re:
01-29-2001 12:44 AM in reply to: *Heiman, Miky
I can't seem to find it now either. I did find TS53457 which has a link to what I believe
to be TS55765 but I get a 404 error when I click on it.
TS53457 lists some other "options"
I'll look around and see if I saved it anywhere and post back if I find it.
sorry
jason martin
"Jeremy McCully" wrote in message
news:3EC221FBB6FD5863B6C1CB8EACE6ED97@in.WebX.SaUCah8kaAW...
> TS55765 ??
> base..
> Jeremy
*McCully, Jeremy
Message 17 of 25 (131 Views)
Re:
01-29-2001 01:14 AM in reply to: *Heiman, Miky
Yeah, I also found TS53457. It mentions Power User and Admin, not valid
options for us either. Here is somthing that has worked so far for myself:
Setup the user as regular USER
Give full control to c:\program files\autocad directory
Give Full control (minus write DAC and write OWNER) to
hkey_local_machine\software
Give Full control to hkey_local_machine\software\autodesk
Still get the annoying "Failed to update registry, please use regedit"
message, but the program seems to run flawlessly after that.
If you can find a copy of that old TS55765 please do post it.
news:81991B0AF419652F8B87B30AB3174C7D@in.WebX.SaUCah8kaAW...
to what I believe
it.
> sorry
> jason martin
> > TS55765 ??
> > base..
> > Jeremy
*McCully, Jeremy
Message 18 of 25 (131 Views)
Re:
01-29-2001 01:32 AM in reply to: *Heiman, Miky
set hkey_local_machine\software\autodesk -> full
set hkey_local_machine\software\classes -> full
the rest only read access
annoying error message gone
news:4A52C481D10997C4F9749E67BC0A647E@in.WebX.SaUCah8kaAW...
> Thanks
> to what I believe
> it.
> > sorry
> > jason martin
> > > TS55765 ??
> > > base..
> > > Jeremy
*Nehls, Kevin
Message 19 of 25 (131 Views)
Re:
01-29-2001 02:54 AM in reply to: *Heiman, Miky
Autodesk knows about this broken link. Also check out these topics in the
Autocad.2000general NG:
1) "Windows 2000 permissions work around" dated 1/22/2001
2) "Power User Required?" dated 1/18/2001
A copy of this missing article was posted by Shaan Hurley in the "Windows
2000 permiss....." discussion.
HTH
Kevin Nehls
(snip)
*martin, jason
Message 20 of 25 (131 Views)
Re:
01-29-2001 03:14 AM in reply to: *Heiman, Miky
Thanks again Kevin.
jason
news:FD8F91724303E2511D8A06FF81CDC51A@in.WebX.SaUCah8kaAW...
> HTH
> Kevin Nehls
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
