Installation & Licensing
Upgrading to Novell 5.1 - switching to NT server - problems
2 REPLIES 2
208 Views, 2 Replies
I have followed the advice of the experts and have decided to switch my ADLM
to an NT server. I have authorized it, started the service, etc. I set up a
couple of workstations to test the new configuration. I have one NT
workstation and one WIN95 station. I have set the ACADSERVER variable to
@servername. AutoCAD will not start on either machine.
I have followed all of the troubleshooting steps of the post:
dated December 30, 1997
by Rodger Kilo, AutoDesk Product Support
with the subject: Tips for troubleshooting an AdLM or the Network version of
R14
I printed it out a long time ago and haven't checked to see if it is still
on the server. Oh, it was on the AutoDesk.AutoCAD.network newsgroup.
Does anyone have any answers? I realize I will probably need to submit some
more information about specific settings, but I'm not sure which ones.
TIA
Larry
2 REPLIES 2
Larry,
First thing to do is get rid of the "@" symbol in your ACADSERVER value.
What that thing does is eliminates AutoCAD's broadcast for a license server.
So, if ACADSERVER is set incorrectly, AutoCAD will not start even if AdLM
server is running on the same machine! You can always add the @ symbol back
to the value once you have isolated and resolved your problem. Next, I
would look at the adlm.log file, there may be error messages there that will
direct you to a problem.
Jerry Milana,
Autodesk Product Support
"Larry Clatt" wrote in message
news:ef06dd8.-1@WebX.SaUCah8kaAW...
ADLM
a
of
> R14
some
> TIA
> Larry
I needed the @ symbol to test my new license server because I wanted the
AutoCAD that I was testing to go ONLY to the NT server for its license.
For those of you who are interested in the "whole switching thing" from
Novell ADLM to NT ADLM:
I fixed the problem by doing a new network deployment from the nt server.
(running \netsetup\setup) At the beginning of the setup process, it allows
you to choose TCP/IP or IPX. That was my clue that my previous network
deployment wouldn't work. I reinstalled AutoCAD on the workstation, restored
my profile and I'm off and running. Also, if you have a shortcut on your
desktop that is called "AutoCAD r14", it overwrites the "start in" folder
with the path to acad.exe.
jerry milana wrote in message
news:ef06dd8.0@WebX.SaUCah8kaAW...
> Larry,
server.
back
will
> Jerry Milana,
> ADLM
up
> a
version
> of
> > R14
still
> some
> > TIA
> > Larry
Administrator Productivity
