• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    *Nehls, Kevin
    Upgrading to 2000 and Authorization codes????
    85 Views, 3 Replies
    01-19-2000 02:59 PM
    We just received the upgrade to A2K and I have been dealt with the task of
    planning, installing, testing, and deploying this program to the server and
    workstations. I would like to know if I could install the products on test
    systems and authorize them and then later reinstall on the "live" server
    and workstations or if I would have to re-authorize everything? In other
    words, is the authorization code hardware dependent or can I use the same
    authorization code with the same serial numbers?
    Thanks in advance,
    Kevin Nehls
    for reply remove -ns-
    Please use plain text.
    *Milana, Jerry
    Re: Upgrading to 2000 and Authorization codes????
    01-19-2000 03:06 PM in reply to: *Nehls, Kevin
    Kevin,
    AdLM authorization is tied to the system so, you will not be able to move it,
    you will need to install AdLM and authorize it when you move to your production
    server. AutoCAD deployments are also tied to the location they were created
    in. This means you will have to create new deployments as opposed to moving
    them from one server to the next.
    Jerry Milana,
    Autodesk Product Support
    > Thanks in advance,
    > Kevin Nehls
    *Nehls, Kevin
    Re:
    01-19-2000 03:22 PM in reply to: *Nehls, Kevin
    Thanks. This is kind of what I thought. It won't be that big of a deal
    since there will only be one deployment for testing, me. As for the
    server, oh well. Currently we have an extra PC that can have NT server
    installed to be used as the test server, but it looks like we are going to
    have to purchase a new server anyhow.
    Once again, thanks for your reply.
    Kevin Nehls
    Jerry Milana wrote in article
    <3886435C.1A9312EF@autodesk.com>...
    > Kevin,
    it,
    production
    created
    moving
    > Jerry Milana,
    *Milana, Jerry
    Re:
    01-19-2000 05:07 PM in reply to: *Nehls, Kevin
    My pleasure, Kevin.
    I think you are going to like AdLM. As far as reinstalling to your production
    server goes, I'll bet you find that pretty easy once you had practice on your
    staging network :smileyhappy:
    Jerry
    > Kevin Nehls
    > > Kevin,
    > it,
    > production
    > created
    > moving
    > > Jerry Milana,
