show this document :
http://usa.autodesk.com/getdoc/id=TS65928
If you want test the new acad2004 based products, just make a standalone
install.
You can't test if you do a network install. (I never see it)
Best regards
Franck Hervet
http://www.aricad.fr
"Dave Lewis" a écrit dans le message de
news:kdstavsa3ukp21p8qidids3ejpgihrttej@4ax.com...
> so for the software that is not being updated I should past in the old
.lic file?
> Right now all we want to do is test the new acad 2004 based products.
Everything
> else we want to stay the same. We are not updating any of the production
people at
> this time, so all the old stuff stays the same.
> On Tue, 29 Apr 2003 10:26:56 -0700, in autodesk.autocad.network you wrote:
> |>If you want use your 2004 licenses, you need to update your FlexLM.
> |>Ask for a new license file for your Map 2004.
> |>Normally, they will give you a file with one section for Map 2004 (2
seats).
> |>And another section to downgrade the number of licenses of Map5.
> |>If no section for Map5, add the section of your actual license file in
the
> |>new file of Map2004.
> |>Do it for 2002 and Ldt3.
