Do wwe have to uninstall the previous installation (2010) before installing Autodesk Design Suite 2011?
Solved by DouglasLauritsen. Go to Solution.
You can install the new release before you uninstall the previous release. The EULA may require that you uninstall the previous release a certain number of days after the new release is installed and activated. When you uninstall the previous release you may need to go to the Programs and Features (Windows 7 and Vista) or Add and Remove Programs (Windows XP) lists to perform a reinstall of the current release.
