Installation & Licensing
New Member
bcaddy
Message 1 of 2 (125 Views)
Upgrades
125 Views, 1 Replies
09-26-2011 12:15 PM
I have recieved an upgrade from Autodesk as I had subscription, which I discontinued -
1) Must I upgrade immediately? Or Do I have some time before I upgrade.
2) The LSA 2012 that I found online - Sec 1.2, 1.2.1 - is confusing me, as it says that I can keep using the old version , and then install an Upgrade , and I have 120 days from when I installed this upgrade to delete all previous copies? What if I never upgrade to a new version , and keep using the old version , will I be mislicensed?
Am I reading wrong ? Or is my interpretion correct?
TravisNave
Message 2 of 2 (108 Views)
Re: Upgrades
09-27-2011 09:17 AM in reply to: bcaddy
If you received an upgrade auto-fulfilled via active Subscription, then your latest version is the version that you received.  Subscription allows you to continue to use your older versions.  However, if you lapse your Subscription, you have 120 days to use your old product and you must upgrade to the latest version.
There really is nothing that will keep you from using your old version.  However, you will be unable to reinstall and reactivate your older version because your old serial number is now invalid due to the expired Subscription.  You will however be able to use and activate your newest version up to the point where you upgrade it or it is no longer supported.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
