Where I can find more information for the Product Design Suite Premium upgrade to Ultimate, with Autodesk Vault(server and client)installed on same machine, with the SQL 2008 Standard, on Windows XP PRO x64 computer?
When the next Product Design Suites release will be out?
Is the Windows 7 better option in OS for the Ultimate Suite installation?
The only reason to get the upgrade is the Inventor 2012 upgrade to Inventor PRO.
Nina
you need to talk to your reseller for pricing info
the next release will probably be spring
windows 7 is a better os
DarrenP
Thank you, we already checked for the price of the upgrade.
I need to know the right way to uninstall Premium Suite(with Vault) and to Install The Ultimate( with Vault).
Nina
you can use the quick uninstall tool that comes with the product design suite
located here: start>all programs>autodesk
DarrenP
Hi ngueorguieva,
You can also refer to these links for the Complete Uninstallation procedure, http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617 and http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10243968&linkID=9240617.
