• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Member
    Uninstalling Maya 2011 from OSX
    11871 Views, 6 Replies
    05-06-2010 12:59 AM
    I've installed Maya 2011 on OSX with a network license, but it seems that the university render farms only support up to 2009. Now I want to uninstall 2011 before installing 2009 to avoid any complications (and because I like a clean computer), but I can't seem to find any uninstall options. Google isn't very helpful either, besides telling me to remove some directories, which I'm not comfortable with yet.
    Any official way on uninstalling Maya 2011 from OSX?
    Please use plain text.
    Valued Mentor
    Re: Uninstalling Maya 2011 from OSX
    05-06-2010 03:44 AM in reply to: SpacyRicochet
    I'm not a Mac user but Google is my friend (Some samples of uninstall) :
    http://area.autodesk.com/forum/autodesk-maya/autodesk-maya-2011/maya-2011-osx-64bit-trial-uninstall/page-last/
    http://support.apple.com/kb/ht1224
    http://guides.macrumors.com/Uninstalling_Applications_in_Mac_OS_X
    Franck Hervet Edited by: frhervet on May 6, 2010 12:46 PM
    Franck Hervet
    S'il vous plaît Marquer cette réponse comme "Accepter comme solution" si elle répond à votre question.
    Member
    05-06-2010 04:40 AM in reply to: SpacyRicochet
    Thanks :smileyhappy: Those are the ones that I found as well, but which I found unhelpful in such a way that it basically means hacking into your own system for basic functionality. And I still won't be sure that it removes everything related to it, which is why I'm hoping that Autodesk has an answer as well. If they want me to delete all kinds of folders, then at least that's the only way.
    Valued Mentor
    05-06-2010 05:51 AM in reply to: SpacyRicochet
    Sorry to not help you more.
    Perhaps an Autodesk person could answer here.
    Good luck.
    Franck Hervet
    Franck Hervet
    05-06-2010 07:18 AM in reply to: SpacyRicochet
    You should have found the instructions on page 29 of the Maya 2011 Installation & Licensing Guide which is available from
    http://images.autodesk.com/adsk/files/maya2011installationlicensingguide.pdf
    Uninstall Maya on Mac OS X
    To uninstall Maya on Mac OS X 1 Navigate to the Maya directory (by default,
    /Applications/Autodesk/maya2011/).
    2 Drag the maya2011 application to the trash.
    3 Open a Terminal window and execute the following commands, where is your product key.:
    adlmreg –u S 2011.0.0.F adlmreg –u N 2011.0.0.F
    Installing and Running the Product | 29
    This ensures that product information is properly removed from the ProductInformation.pit file.
    These instructions don't tell you what the product key is. For Maya 2011, it is 657C1
    The instructions don't mention it, but once you have installed Autodesk software, you have also installed their licensing tools. Removing Maya does not remove those.
    I'm not sure what exactly Autodesk's official position is on removing all traces of their licensing (AdLM). As far as I know, it is not possible. Some information is provided on page 62 of the Maya 2011 Installation & Licensing Guide.
    Member
    05-06-2010 11:54 PM in reply to: SpacyRicochet
    Thanks for all the help guys :smileyhappy:
    In the end, I just reinstalled OSX entirely. Wasn't a big issue, since Maya was the first program I installed. And it gave me a chance to see how fast that goes. Maya 2009 is working like a charm. Do have to say that not providing proper uninstallers is kind of a pain, but perhaps that's just something that I have to get used to when dealing with Apple programs.
    Product Support
    02-27-2013 01:55 PM in reply to: SpacyRicochet
    I have updated this blog post to make the uninstall Maya 2013-2010 a bit easier.
    http://upandready.typepad.com/up_and_ready/2012/04/maya-2012-on-mac-how-to-delete-maya-from-your-com...
    David Lau
    Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution. :smileywink:
    My 5 Top Issues in the Discussion Groups
    1402 Error [Uninstall] | Faro doesn't install | adlmPITSetProductInformation Errors | Empty Tool bar in AutoCAD Mac | Win 7 Registry Limit
