I've used the PDSU 2014 uninstall tool to uninstall a selection of the software to make space, but after it was finished the tool itself is no longer available from the start menu.
I'm not sure if it's still accessable, since i don't know where it's located.
Can someone point me to where this tool is supposed to reside on a windows 7 machine, so i can check if it hasn't uninstalled itself?
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Solved by DarrenP. Go to Solution.
i would think it would be installed under Program Files>Autodesk
but i can't seem to find it
DarrenP
found it
it should be under here Program files (x86)>common files>autodesk shared>uninstall tool
DarrenP
i also found it on the USB stick or download
x64\Mudbox\Program Files\Autodesk\Mudbox2014\PFiles\CommFiles\Autodesk Shared\Uninstall Tool\R1
DarrenP
Niels van der Veer
The Netherlands
Niels van der Veer
The Netherlands
