Hello please can you help me is there an uninstall tool for Autodesk Building Design Suite Ultimate 2013
regards
It will not work i went to uninstall my AutoCAD 2013 and then i delete the folder of autocad 2013 and my Autocad Architecture 2013 will not work any more i went to the controle panel and try to uninstall it but it will not let me it say the program is no longer on the system but if i want to install the program again it says program is already install
i need an uninstall tool for AutoCAD Architecture 2013
Can you help me
Regards
it doesn't look autodesk updated it for 2013: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17031128&linkID=9240617
DarrenP
did you try this: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
DarrenP
Hi mr_kroes,
Here's the link for the Design Suite 2013 Automated Uninstall.
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
For all other installation problems on Windows XP SP2 or below consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
