How does one uninstall software that does not display in the add/remove dialog box? Very few programs show up.
XP Version 5.1 SP3
Thank you,
There maybe something wrong with your install or uninstall process.
You can visit Microsoft websit and download the tool Windows Install Clean Up, and then install the tool, use it to uninstall the product.
Thank you for the quick reply.
I found this on the Microsoft website:
Article ID: 290301 - Last Review: June 25, 2010 - Revision: 11.0
This article was previously published under Q290301
Notice<script type="text/javascript">// loadTOCNode(1, 'notice'); // </script>
This article previously contained a link to the Windows Installer Cleanup utility (MSICUU2.exe). If you were directed to this article to solve a problem installing a product other than Microsoft Office, please contact your software manufacturer for installation support on the product.
While the Windows Installer Cleanup utility resolved some installation problems, it sometimes damaged other components installed on the computer. Because of this, the tool has been removed from the Microsoft Download Center. The Fix it Solutions in this article provide the ability to fully remove Office 2003, 2007 and 2010 suites without damaging other Windows components.
This article covers Office versions 2003, 2007 and 2010. Additionally, there is an article that covers steps to manually remove Office 2007. For more information, click the following article number to view the article in the Microsoft Knowledge Base:
You can find in attachment, change the file to .exe, then install and remove your application.
good luck.
