Installation & Licensing
Active Member
thomasseguin
Message 1 of 3 (9,115 Views)
Uninstall Tool 2014
9115 Views, 2 Replies
04-04-2013 07:12 AM
We have a large base of Autodesk products installed. In 2013, we used uninstall tool  (C:\Program Files\Autodesk\Uninstall Tool 2013\InvCleanup.exe) to uninstall products in silent mode by a send to workstations a dos command like
"C:\Program Files\Autodesk\Uninstall Tool 2013\InvCleanup.exe" /qn
It wasn't a conventional method but it worked perfectly with a fast and simple uninstall.
In 2014 Uninstalltool.exe seems to be changed and I don't find solution to run it in silent mode with some arguements in dos or another way
Have you some correct arguments or other method to run uninstalltool.exe in silent mode ?
Message 2 of 3 (9,077 Views)
Re: Uninstall Tool 2014
04-04-2013 06:26 PM in reply to: thomasseguin
The uninstall batch file is found in the SMS_SCCM scripts folder of the deployment.
Jimmy Bergmark
JTB World - Software development and consulting
Specialities: AutoCAD, AutoCAD Architecture and Revit
http://www.jtbworld.com
JTB FlexReport - network license reports
http://www.jtbworld.com/jtbflexreport/index.htm
New Member
Message 3 of 3 (9,072 Views)
04-04-2013 10:19 PM in reply to: thomasseguin
For deployment user, you can find a script folder under deployment Admin image folder, named "SMS_SCCM scripts", there is txt files named like #deploymentName#_Uninstall.txt to uninstall products which installed from the deployment.  How to turn the txt file into BAT file to run, you can follow the instruction in "Product_Uninstall_ReadMe.txt" (Which is attached)
For Uninstall Tool, there is no silent command yet.
Arron
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
