• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Uninstall Error- AutoCAD Civil 3D 2012 32 Bit Object Enabler for SSA
    1049 Views, 2 Replies
    04-12-2012 08:48 AM
    I am trying to uninstall AutoCAD Civil 3D 2012 32 Bit Object Enabler  for SSA version 1619.0  so I can install Civil 3D 2013 and I get this:
    "Error 1606. Could not access network location 0."
    I already uninstalled Civil 2012 & SSA is not on my machine.
    1. Do I need to install SSA 2012 to uninstall the enabler?
    2.  If so can I just install SSA 2012 without installing Civil 3D 2012?
    EB
    HP Z400 Workstation
    Intel Xeon W3550 -Cores 4
    12GB Triple-Channel DDR3 @ 533MHz
    2-HP LE2201w @ 1680x1050
    ATI FirePro V3800 (FireGL) (HP)
    MS Windows 7 64-bit
    Please use plain text.
    TravisNave
    Re: Uninstall Error- AutoCAD Civil 3D 2012 32 Bit Object Enabler for SSA
    04-12-2012 05:24 PM in reply to: everblader
    You might not have access to the original install location:
    To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
    http://support.microsoft.com/mats/Program_Install_and_Uninstall
    For more information on the Autodesk KB Support article concerning the clean uninstall of Autdoesk products, see this link:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
    For all other installation problems on Windows XP SP2 or below consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
    http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    04-13-2012 07:20 AM in reply to: TravisNave
    Thanks, the Diagnose and Fix installation problems from Microsoft worked and removed the enabler.
    Thanks again!
    HP Z400 Workstation
    MS Windows 7 64-bit
