Installation & Licensing
Uninstall Error- AutoCAD Civil 3D 2012 32 Bit Object Enabler for SSA
2 REPLIES 2
everblader
4156 Views, 2 Replies
I am trying to uninstall AutoCAD Civil 3D 2012 32 Bit Object Enabler  for SSA version 1619.0  so I can install Civil 3D 2013 and I get this:
"Error 1606. Could not access network location 0."
I already uninstalled Civil 2012 & SSA is not on my machine.
1. Do I need to install SSA 2012 to uninstall the enabler?
2.  If so can I just install SSA 2012 without installing Civil 3D 2012?
EB
HP Z400 Workstation
Intel Xeon W3550 -Cores 4
12GB Triple-Channel DDR3 @ 533MHz
2-HP LE2201w @ 1680x1050
ATI FirePro V3800 (FireGL) (HP)
MS Windows 7 64-bit
2 REPLIES 2
TravisNave
in reply to: everblader
You might not have access to the original install location:
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autdoesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
For all other installation problems on Windows XP SP2 or below consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
Autodesk Forums:
everblader
in reply to: TravisNave
Thanks, the Diagnose and Fix installation problems from Microsoft worked and removed the enabler.
Thanks again!
HP Z400 Workstation
MS Windows 7 64-bit
Administrator Productivity
