Installation & Licensing
Unable to start the lincense server on a Mac
40 REPLIES 40
Message 1 of 41
skylab1701
4812 Views, 40 Replies
I am having problem starting the lincense server on a Mac running 10.7 server, I have followed the Quick Start: Setting up a license server on Mac guide and having any luck to get it going, below is the log for the errors:
Can anyone point out what am I doing wrong?
Robert
Cerritos:flexnetserver root# sudo chmod -R 777 /var/flexlm
Cerritos:flexnetserver root# cd /usr/local/flexnetserver
Cerritos:flexnetserver root# ls
.waitForNetwork            adskflex
LicenseAdministration.pdf    lmgrd
adlmctl                lmgrdLauncher
adsk_server.lic            lmutil
Cerritos:flexnetserver root# sudo ./lmgrd -c /var/flexlm/adsk_server.lic
 9:55:21 (lmgrd) -----------------------------------------------
 9:55:21 (lmgrd)   Please Note:
 9:55:21 (lmgrd)
 9:55:21 (lmgrd)   This log is intended for debug purposes only.
 9:55:21 (lmgrd)   In order to capture accurate license
 9:55:21 (lmgrd)   usage data into an organized repository,
 9:55:21 (lmgrd)   please enable report logging. Use Flexera Software LLC's
 9:55:21 (lmgrd)   software license administration  solution,
 9:55:21 (lmgrd)   FlexNet Manager, to  readily gain visibility
 9:55:21 (lmgrd)   into license usage data and to create
 9:55:21 (lmgrd)   insightful reports on critical information like
 9:55:21 (lmgrd)   license availability and usage. FlexNet Manager
 9:55:21 (lmgrd)   can be fully automated to run these reports on
 9:55:21 (lmgrd)   schedule and can be used to track license
 9:55:21 (lmgrd)   servers and usage across a heterogeneous
 9:55:21 (lmgrd)   network of servers including Windows NT, Linux
 9:55:21 (lmgrd)   and UNIX. Contact Flexera Software LLC at
 9:55:21 (lmgrd)   www.flexerasoftware.com for more details on how to
 9:55:21 (lmgrd)   obtain an evaluation copy of FlexNet Manager
 9:55:21 (lmgrd)   for your enterprise.
 9:55:21 (lmgrd)
 9:55:21 (lmgrd)
 9:55:21 (lmgrd)
 9:55:21 (lmgrd) The license server manager (lmgrd) running as root:
 9:55:21 (lmgrd)     This is a potential security problem
 9:55:21 (lmgrd)     and is not recommended.
Cerritos:flexnetserver root#  9:55:23 (lmgrd) FlexNet Licensing (v11.11.0.2 build 115032 x64_mac10) started on Cerritos.edu (Mac) (5/30/2013)
 9:55:23 (lmgrd) Copyright (c) 1988-2012 Flexera Software LLC. All Rights Reserved.
 9:55:23 (lmgrd) World Wide Web:  http://www.flexerasoftware.com
 9:55:23 (lmgrd) License file(s): /var/flexlm/adsk_server.lic
 9:55:23 (lmgrd) lmgrd tcp-port 27001
 9:55:23 (lmgrd) The license server manager has found no vendor daemons to start
 9:55:23 (lmgrd)  (There are no VENDOR (or DAEMON) lines in the license file),
    lmgrd exiting.
 (Cannot connect to license server system.
 The license server manager (lmgrd) has not been started yet,
 the wrong port@host or license file is being used, or the
 port or hostname in the license file has been changed.
Server name:   Cerritos.edu
License path:  /var/flexlm/adsk_server.lic:
FLEXnet Licensing error:-15,570.  System Error: 36 "Operation now in progress"
For further information, refer to the FLEXnet Licensing documentation,
available at "www.flexerasoftware.com".)
.waitForNetwork            adsk_server.lic            lmgrdLauncher
LicenseAdministration.pdf    adskflex            lmutil
adlmctl                lmgrd
10:00:51 (lmgrd) -----------------------------------------------
10:00:51 (lmgrd)   Please Note:
10:00:51 (lmgrd)
10:00:51 (lmgrd)   This log is intended for debug purposes only.
10:00:51 (lmgrd)   In order to capture accurate license
10:00:51 (lmgrd)   usage data into an organized repository,
10:00:51 (lmgrd)   please enable report logging. Use Flexera Software LLC's
10:00:51 (lmgrd)   software license administration  solution,
10:00:51 (lmgrd)   FlexNet Manager, to  readily gain visibility
10:00:51 (lmgrd)   into license usage data and to create
10:00:51 (lmgrd)   insightful reports on critical information like
10:00:51 (lmgrd)   license availability and usage. FlexNet Manager
10:00:51 (lmgrd)   can be fully automated to run these reports on
10:00:51 (lmgrd)   schedule and can be used to track license
10:00:51 (lmgrd)   servers and usage across a heterogeneous
10:00:51 (lmgrd)   network of servers including Windows NT, Linux
10:00:51 (lmgrd)   and UNIX. Contact Flexera Software LLC at
10:00:51 (lmgrd)   www.flexerasoftware.com for more details on how to
10:00:51 (lmgrd)   obtain an evaluation copy of FlexNet Manager
10:00:51 (lmgrd)   for your enterprise.
10:00:51 (lmgrd)
10:00:51 (lmgrd)
10:00:51 (lmgrd)
10:00:51 (lmgrd) The license server manager (lmgrd) running as root:
10:00:51 (lmgrd)     This is a potential security problem
10:00:51 (lmgrd)     and is not recommended.
Cerritos:flexnetserver root# 10:00:51 (lmgrd) FlexNet Licensing (v11.11.0.2 build 115032 x64_mac10) started on Cerritos.edu (Mac) (5/30/2013)
10:00:51 (lmgrd) Copyright (c) 1988-2012 Flexera Software LLC. All Rights Reserved.
10:00:51 (lmgrd) World Wide Web:  http://www.flexerasoftware.com
10:00:51 (lmgrd) License file(s): /var/flexlm/adsk_server.lic
10:00:51 (lmgrd) lmgrd tcp-port 27001
10:00:51 (lmgrd) The license server manager has found no vendor daemons to start
10:00:51 (lmgrd)  (There are no VENDOR (or DAEMON) lines in the license file),
    lmgrd exiting.
40 REPLIES 40
Message 21 of 41
skylab1701
in reply to: TravisNave
assuming that's the case, how can I fix the problem?
Message 22 of 41
TravisNave
in reply to: skylab1701
Yeah, my only recommendation is to go back thru it step by step. I
typically support it on Windows. But it's basically the same but without a
decent GUI.
Autodesk Forums:
Message 23 of 41
skylab1701
Do you know anyone support the Mac, Smoke is only available on Mac.
Message 24 of 41
Robert.Adam
Hi.
What is the exact issue? Can you please take a look at the logs? Here's how:
1. Open Finder and press Command+Shift+G
2. Enter "/var/log/autodesk" in the field that pops up, then press Go. This will take you to the lic server's log folder.
3. Open the adlm_flexnetserver.log file and look for error messages. Post anything you find here.
If the error in the log is "Wrong hostid" , and you are running OS X 10.8, then you might be experiencing a known bug, documented in this KB article: http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=21280818&linkID=9242618&siteID=123112
If that's the issue, please try the workarounds in that article.
Robert Adam.
Autodesk Smoke Premium Support
Robert Adam
Program Manager
Message 25 of 41
skylab1701
in reply to: Robert.Adam
Hi Robert,
I am off today, I will pull the log and post it here when I return on Monday.
Message 26 of 41
skylab1701
Here is the log:
15:27:53 (lmgrd) -----------------------------------------------
15:27:53 (lmgrd)   Please Note:
15:27:53 (lmgrd)
15:27:53 (lmgrd)   This log is intended for debug purposes only.
15:27:53 (lmgrd)   In order to capture accurate license
15:27:53 (lmgrd)   usage data into an organized repository,
15:27:53 (lmgrd)   please enable report logging. Use Flexera Software LLC's
15:27:53 (lmgrd)   software license administration  solution,
15:27:53 (lmgrd)   FlexNet Manager, to  readily gain visibility
15:27:53 (lmgrd)   into license usage data and to create
15:27:53 (lmgrd)   insightful reports on critical information like
15:27:53 (lmgrd)   license availability and usage. FlexNet Manager
15:27:53 (lmgrd)   can be fully automated to run these reports on
15:27:53 (lmgrd)   schedule and can be used to track license
15:27:53 (lmgrd)   servers and usage across a heterogeneous
15:27:53 (lmgrd)   network of servers including Windows NT, Linux
15:27:53 (lmgrd)   and UNIX. Contact Flexera Software LLC at
15:27:53 (lmgrd)   www.flexerasoftware.com for more details on how to
15:27:53 (lmgrd)   obtain an evaluation copy of FlexNet Manager
15:27:53 (lmgrd)   for your enterprise.
15:27:53 (lmgrd)
15:27:53 (lmgrd)
15:27:53 (lmgrd)
15:27:53 (lmgrd) The license server manager (lmgrd) running as root:
15:27:53 (lmgrd)     This is a potential security problem
15:27:53 (lmgrd)     and is not recommended.
15:28:18 (lmgrd) FlexNet Licensing (v11.11.0.2 build 115032 x64_mac10) started on Cerritos.edu (Mac) (6/5/2013)
15:28:18 (lmgrd) Copyright (c) 1988-2012 Flexera Software LLC. All Rights Reserved.
15:28:18 (lmgrd) World Wide Web:  http://www.flexerasoftware.com
15:28:18 (lmgrd) License file(s): /usr/local/flexnetserver/adsk_server.lic
15:28:18 (lmgrd) lmgrd tcp-port 27000
15:28:18 (lmgrd) Starting vendor daemons ...
15:28:18 (lmgrd) Using vendor daemon port 2080 specified in license file
15:28:18 (lmgrd) Started adskflex (internet tcp_port 2080 pid 277)
15:28:21 (adskflex) Unable to initialize access to trusted storage: 1
15:28:21 (adskflex) FlexNet Licensing version v11.11.0.2 build 115032 x64_mac10
15:28:22 (adskflex) Server started on Cerritos.edu for:    85937SMKMAC_2013_0F
15:28:22 (adskflex) 85937SMKMACWG_2013_0F 85937SMKMACBRN_2013_0F
15:28:22 (adskflex) EXTERNAL FILTERS are OFF
15:28:22 (adskflex) Vendor daemon can't talk to lmgrd (Cannot connect to license server system. (-15,570:36 "Operation now in progress"))
15:28:22 (adskflex) EXITING DUE TO SIGNAL 37 Exit reason 5
15:28:22 (lmgrd) adskflex exited with status 37 (Communications error)
15:28:22 (lmgrd) Since this is an unknown status, license server
15:28:22 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
15:28:22 (lmgrd) Using vendor daemon port 2080 specified in license file
15:28:22 (lmgrd) REStarted adskflex (internet tcp_port 2080 pid 285)
15:28:22 (adskflex) Unable to initialize access to trusted storage: 1
15:28:22 (adskflex) FlexNet Licensing version v11.11.0.2 build 115032 x64_mac10
15:28:23 (adskflex) Server started on Cerritos.edu for:    85937SMKMAC_2013_0F
15:28:23 (adskflex) 85937SMKMACWG_2013_0F 85937SMKMACBRN_2013_0F
15:28:23 (adskflex) EXTERNAL FILTERS are OFF
15:28:23 (adskflex) Vendor daemon can't talk to lmgrd (Cannot connect to license server system. (-15,570:36 "Operation now in progress"))
15:28:23 (adskflex) EXITING DUE TO SIGNAL 37 Exit reason 5
15:28:23 (lmgrd) adskflex exited with status 37 (Communications error)
15:28:23 (lmgrd) Since this is an unknown status, license server
15:28:23 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
15:28:23 (lmgrd) Using vendor daemon port 2080 specified in license file
15:28:23 (lmgrd) REStarted adskflex (internet tcp_port 2080 pid 286)
15:28:23 (adskflex) Unable to initialize access to trusted storage: 1
15:28:23 (adskflex) FlexNet Licensing version v11.11.0.2 build 115032 x64_mac10
15:28:23 (lmgrd) REStarted adskflex (internet tcp_port 2080 pid 287)
15:28:23 (lmgrd) REStarted adskflex (internet tcp_port 2080 pid 288)
15:28:23 (lmgrd) REStarted adskflex (internet tcp_port 2080 pid 289)
15:28:23 (lmgrd) REStarted adskflex (internet tcp_port 2080 pid 290)
15:28:23 (lmgrd) REStarted adskflex (internet tcp_port 2080 pid 291)
15:28:23 (lmgrd) REStarted adskflex (internet tcp_port 2080 pid 292)
15:28:24 (adskflex) Unable to initialize access to trusted storage: 1
15:28:24 (adskflex) FlexNet Licensing version v11.11.0.2 build 115032 x64_mac10
15:28:24 (adskflex) Server started on Cerritos.edu for:    85937SMKMAC_2013_0F
15:28:24 (adskflex) 85937SMKMACWG_2013_0F 85937SMKMACBRN_2013_0F
15:28:24 (adskflex) EXTERNAL FILTERS are OFF
15:28:24 (adskflex) Vendor daemon can't talk to lmgrd (Cannot connect to license server system. (-15,570:36 "Operation now in progress"))
15:28:24 (adskflex) EXITING DUE TO SIGNAL 37 Exit reason 5
15:28:24 (lmgrd) adskflex exited with status 37 (Communications error)
15:28:24 (lmgrd) Since this is an unknown status, license server
15:28:24 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
15:28:24 (lmgrd) Using vendor daemon port 2080 specified in license file
15:28:24 (lmgrd) REStarted adskflex (internet tcp_port 2080 pid 293)
15:28:24 (lmgrd) REStarted adskflex (internet tcp_port 2080 pid 294)
15:28:24 (lmgrd) Please correct problem and restart daemons
21:28:18 (lmgrd) TIMESTAMP 6/5/2013
 3:28:18 (lmgrd) TIMESTAMP 6/6/2013
 9:28:18 (lmgrd) TIMESTAMP 6/6/2013
15:28:18 (lmgrd) TIMESTAMP 6/6/2013
21:28:18 (lmgrd) TIMESTAMP 6/6/2013
 3:28:18 (lmgrd) TIMESTAMP 6/7/2013
 9:28:18 (lmgrd) TIMESTAMP 6/7/2013
15:28:18 (lmgrd) TIMESTAMP 6/7/2013
21:28:18 (lmgrd) TIMESTAMP 6/7/2013
 3:28:18 (lmgrd) TIMESTAMP 6/8/2013
 9:28:18 (lmgrd) TIMESTAMP 6/8/2013
15:28:18 (lmgrd) TIMESTAMP 6/8/2013
21:28:18 (lmgrd) TIMESTAMP 6/8/2013
 3:28:18 (lmgrd) TIMESTAMP 6/9/2013
 9:28:18 (lmgrd) TIMESTAMP 6/9/2013
15:28:18 (lmgrd) TIMESTAMP 6/9/2013
21:28:18 (lmgrd) TIMESTAMP 6/9/2013
 3:28:18 (lmgrd) TIMESTAMP 6/10/2013
Message 27 of 41
TravisNave
Looks like you are finally getting somewhere.  The -15 error you are getting typically is caused by Firewall or other communication error.  On Windows Servers, it is generally caused by IPv6 DNS errors.  So it could be one of those two issues on your system as well.
Autodesk Forums:
Message 28 of 41
skylab1701
I am not sure how the fiewall can cause problem, the server and stations are all reside within the same subnet, and we are not using IPv6 at all.  I don't have full acces to the network resource only IT people have access, on this campus IT don't support Mac. When it comes to the Mac I am on my own, therefore, before I go to IT I need to find out the exact cause of the problem, if this is a network communication related issue.
Message 29 of 41
TravisNave
The reason it could be firewall is that port 27000-27009 is not a commonly used port.  Also, just because you don't use IPv6 doesn't mean its not being used.  Can you do a PING of the license server and get an IPv4 address?  How about from the Mac itself to itself?  Same?
Autodesk Forums:
Message 30 of 41
skylab1701
Here is the ping result from my computer to the server, note the IP is static.
PING 10.41.2.2 (10.41.2.2): 56 data bytes
64 bytes from 10.41.2.2: icmp_seq=0 ttl=64 time=0.298 ms
64 bytes from 10.41.2.2: icmp_seq=1 ttl=64 time=0.319 ms
64 bytes from 10.41.2.2: icmp_seq=2 ttl=64 time=0.336 ms
64 bytes from 10.41.2.2: icmp_seq=3 ttl=64 time=0.349 ms
64 bytes from 10.41.2.2: icmp_seq=4 ttl=64 time=0.331 ms
64 bytes from 10.41.2.2: icmp_seq=5 ttl=64 time=0.312 ms
64 bytes from 10.41.2.2: icmp_seq=6 ttl=64 time=0.358 ms
64 bytes from 10.41.2.2: icmp_seq=7 ttl=64 time=0.301 ms
64 bytes from 10.41.2.2: icmp_seq=8 ttl=64 time=0.363 ms
64 bytes from 10.41.2.2: icmp_seq=9 ttl=64 time=0.376 ms
--- 10.41.2.2 ping statistics ---
10 packets transmitted, 10 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 0.298/0.334/0.376/0.026 ms
This is the ping resutl form the server itself
Ping has started…
64 bytes from 10.41.2.2: icmp_seq=0 ttl=64 time=0.059 ms
64 bytes from 10.41.2.2: icmp_seq=1 ttl=64 time=0.042 ms
64 bytes from 10.41.2.2: icmp_seq=2 ttl=64 time=0.048 ms
64 bytes from 10.41.2.2: icmp_seq=3 ttl=64 time=0.083 ms
64 bytes from 10.41.2.2: icmp_seq=4 ttl=64 time=0.066 ms
64 bytes from 10.41.2.2: icmp_seq=5 ttl=64 time=0.076 ms
64 bytes from 10.41.2.2: icmp_seq=6 ttl=64 time=0.071 ms
64 bytes from 10.41.2.2: icmp_seq=7 ttl=64 time=0.055 ms
64 bytes from 10.41.2.2: icmp_seq=8 ttl=64 time=0.077 ms
64 bytes from 10.41.2.2: icmp_seq=9 ttl=64 time=0.093 ms
round-trip min/avg/max/stddev = 0.042/0.067/0.093/0.015 ms
Message 31 of 41
TravisNave
Do a PING by hostname and not IP address.  It makes a big difference.
Autodesk Forums:
Message 32 of 41
skylab1701
Ping has started…
PING cerritos.edu (10.1.1.28): 56 data bytes
64 bytes from 10.1.1.28: icmp_seq=0 ttl=127 time=0.318 ms
64 bytes from 10.1.1.28: icmp_seq=1 ttl=127 time=0.299 ms
64 bytes from 10.1.1.28: icmp_seq=2 ttl=127 time=0.352 ms
64 bytes from 10.1.1.28: icmp_seq=3 ttl=127 time=0.272 ms
64 bytes from 10.1.1.28: icmp_seq=4 ttl=127 time=0.364 ms
64 bytes from 10.1.1.28: icmp_seq=5 ttl=127 time=0.424 ms
64 bytes from 10.1.1.28: icmp_seq=6 ttl=127 time=0.365 ms
64 bytes from 10.1.1.28: icmp_seq=7 ttl=127 time=0.347 ms
64 bytes from 10.1.1.28: icmp_seq=8 ttl=127 time=0.377 ms
64 bytes from 10.1.1.28: icmp_seq=9 ttl=127 time=0.424 ms
--- cerritos.edu ping statistics ---
round-trip min/avg/max/stddev = 0.272/0.354/0.424/0.047 ms
I see the problem here, the hostname of  server is the same as the domain name which is a totally different server reside in IT building.
When I type hostname in terminal to find the hostname of the Mac "cerritos.edu" is what displayed, the actual server name is CaiMacServ, but the IP address of the server is statics not DHCP.  When I type hostname of my Mac, it return MAC-043278.local, completely different from the server, and my Mac is on DHCP.  See attached screen cap of the server network address, notice the DNS server address is 127.0.0.1, where my mac show a different DNS server 10.1.1.24, .28....etc.  The network config is what IT told me to use inclue the DNS.
Any ideas?
Message 33 of 41
TravisNave
Windows uses a hosts file to redirect hostnames to IP addresses. I assume
Mac has something similar.
Autodesk Forums:
Message 34 of 41
skylab1701
I not sure how mac use it, even if is the same as PC I still need a work around to get the server going.
Message 35 of 41
TravisNave
Message 36 of 41
skylab1701
I've tried that and now the Cerritos.edu is point at the server where the license server is installed.
Ping has started…
PING cerritos.edu (10.41.2.2): 56 data bytes
64 bytes from 10.41.2.2: icmp_seq=1 ttl=64 time=0.051 ms
64 bytes from 10.41.2.2: icmp_seq=2 ttl=64 time=0.052 ms
64 bytes from 10.41.2.2: icmp_seq=3 ttl=64 time=0.056 ms
64 bytes from 10.41.2.2: icmp_seq=4 ttl=64 time=0.060 ms
64 bytes from 10.41.2.2: icmp_seq=5 ttl=64 time=0.050 ms
64 bytes from 10.41.2.2: icmp_seq=6 ttl=64 time=0.063 ms
64 bytes from 10.41.2.2: icmp_seq=7 ttl=64 time=0.051 ms
64 bytes from 10.41.2.2: icmp_seq=8 ttl=64 time=0.052 ms
64 bytes from 10.41.2.2: icmp_seq=9 ttl=64 time=0.053 ms
round-trip min/avg/max/stddev = 0.050/0.055/0.063/0.004 ms
I tried to restart the license server again and the server still won't start
 9:40:48 (lmgrd) -----------------------------------------------
 9:40:48 (lmgrd)   Please Note:
 9:40:48 (lmgrd)
 9:40:48 (lmgrd)   This log is intended for debug purposes only.
 9:40:48 (lmgrd)   In order to capture accurate license
 9:40:48 (lmgrd)   usage data into an organized repository,
 9:40:48 (lmgrd)   please enable report logging. Use Flexera Software LLC's
 9:40:48 (lmgrd)   software license administration  solution,
 9:40:48 (lmgrd)   FlexNet Manager, to  readily gain visibility
 9:40:48 (lmgrd)   into license usage data and to create
 9:40:48 (lmgrd)   insightful reports on critical information like
 9:40:48 (lmgrd)   license availability and usage. FlexNet Manager
 9:40:48 (lmgrd)   can be fully automated to run these reports on
 9:40:48 (lmgrd)   schedule and can be used to track license
 9:40:48 (lmgrd)   servers and usage across a heterogeneous
 9:40:48 (lmgrd)   network of servers including Windows NT, Linux
 9:40:48 (lmgrd)   and UNIX. Contact Flexera Software LLC at
 9:40:48 (lmgrd)   www.flexerasoftware.com for more details on how to
 9:40:48 (lmgrd)   obtain an evaluation copy of FlexNet Manager
 9:40:48 (lmgrd)   for your enterprise.
 9:40:48 (lmgrd)
 9:40:48 (lmgrd)
 9:40:48 (lmgrd)
 9:40:48 (lmgrd) The license server manager (lmgrd) running as root:
 9:40:48 (lmgrd)     This is a potential security problem
 9:40:48 (lmgrd)     and is not recommended.
Cerritos:flexnetserver root#  9:40:49 (lmgrd) FlexNet Licensing (v11.11.0.2 build 115032 x64_mac10) started on Cerritos.edu (Mac) (6/11/2013)
 9:40:49 (lmgrd) Copyright (c) 1988-2012 Flexera Software LLC. All Rights Reserved.
 9:40:49 (lmgrd) World Wide Web:  http://www.flexerasoftware.com
 9:40:49 (lmgrd) License file(s): /var/flexlm/adsk_server.lic
 9:40:49 (lmgrd) lmgrd tcp-port 27001
 9:40:49 (lmgrd) The license server manager has found no vendor daemons to start
 9:40:49 (lmgrd)  (There are no VENDOR (or DAEMON) lines in the license file),
    lmgrd exiting.
 (License server machine is down or not responding.
It keep saying no vendor daemons to start, and tcp port 27001, according to the license file this is what it has "VENDOR adskflex port=2080", do I need a new license file?
Message 37 of 41
Robert.Adam
Hi.
The server might be unable to read your license file properly (for example because the file is DOS-formatted instead of being UNIX-formatted).
Try the solution in this Knowledge Base article to test the file encoding and fix it if necessary: http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=21284429&linkID=9242618&siteID=123112
Please let me know if that worked.
Robert.
Robert Adam
Program Manager
Message 38 of 41
skylab1701
Hi Robert,
I've converted the license file from dos to unix, now I am getting a -2,42007 invalid license file syntax error.
so may be the file wasn't converted correctly?  vim check out OK no more ^M at end of the line.
this is what coverted unix format looks like:
SERVER Cerritos.edu 0019e33c5d51USE_SERVERVENDOR adskflex port=2080INCREMENT 85937SMKMAC_2013_0F adskflex 1.000 02-jun-2014 30 \ VENDOR_STRING=educational:extendable SUPERSEDE DUP_GROUP=UH \ ISSUED=20-May-2013 BORROW=4320 SN=xxx-xxxxxxxx SIGN="11E1 0C8B \ B69F AB35 3306 94DE E92F 1CE8 A36D 4518 668E 52A5 B108 8804 \ E398 1B75 60FD FDC3 40D0 6384 0168 36E7 C49C 8539 1F8B 5199 \ 788A 66EA 430B 24A7" SIGN2="0A09 161F 84A0 3D0A F2CC 419E B5F9 \ 821D 0D4B C43E F3A9 879E E246 7357 E35B 006F D557 6C04 6D31 \ 8B4E 16A1 5738 1E62 E9EA 64A2 5BF4 A77C 9AC8 A38C 9A04" INCREMENT 85937SMKMACWG_2013_0F adskflex 1.000 02-jun-2014 60 \ VENDOR_STRING=educational:extendable SUPERSEDE DUP_GROUP=UH \ ISSUED=20-May-2013 BORROW=4320 SN=xxx-xxxxxxxx SIGN="0239 F27A \ 2352 DC02 9844 CAA6 7FE4 D50F 8523 61E7 6235 FF5C D7FD 6B93 \ 5B38 0912 B276 39AB ECBB DE91 23BF A45E 6CED D35E 22EC 8CA6 \ 1A94 62E3 A7F5 EE23" SIGN2="026A 0A38 90F3 8530 ED58 C96C F542 \ 3763 4ED2 7702 B9FD 6F0A 6536 8747 8861 13B7 AE7D 73AA 3F7A \ 37A3 25F2 3578 2949 36B8 D0E8 E14A BDE1 BC07 2A99 A01A" INCREMENT 85937SMKMACBRN_2013_0F adskflex 1.000 02-jun-2014 30 \ VENDOR_STRING=educational:extendable SUPERSEDE DUP_GROUP=UH \ ISSUED=20-May-2013 BORROW=4320 SN=xxx-xxxxxxxx SIGN="0E9C 1780 \    151A 6D4F C415 BEA6 6CB5 A803 C82E C841 AF38 035C 233A 1654 \ A571 0744 37C7 72D1 34CB 851D 052B F8A1 0291 62FF 969F CE2C \ 9547 964E 7462 898B" SIGN2="0CBC D646 A10B C8DA 36EA 0E83 AD66 \ 0B5A E46B 7BCB 46B2 1150 8F0F 51C1 8C50 13F7 5AAA 928E 1AEA \ C08D 24D4 31D8 5ED1 132D 59CC E4B9 8187 7F60 F88C C43C"
Message 39 of 41
Robert.Adam
Hi.
That doesn't look right. In a non-Terminal text editor the file should look just as it did before the conversion.
When you tested the file in vim before the converision, did it have the ^M character at the end of each line? If not, you should not have continued with the conversion.
Do you still have the original file you received from us? If so, can you please email it to me? I'll check and covert it for you if necessary. E-mail it to robert dot adam at autodesk dot com
Thanks!
Robert.
Robert Adam
Program Manager
Message 40 of 41
skylab1701
When I test the file with vim it does show the ^m at the end of the each line, I'll will email you the license file to you.
Robert
Administrator Productivity
