Installation & Licensing
Message 11 of 33 (98 Views)
Re: Unable to start license manager
07-08-2013 12:15 PM in reply to: DarrenP
Hi Darren,
I have the firewall off on the server.
*Expert Elite*
DarrenP
Message 12 of 33 (91 Views)
07-08-2013 12:31 PM in reply to: estauss
you can try starting from scratch by removing the service and setting it up again
before setting it up again make sure the lmgrd and the adskflex.exe are not running in the background via task manager also check the windows services to make sure the flex lm service isn't running
Message 13 of 33 (89 Views)
07-08-2013 12:40 PM in reply to: DarrenP
Tried that, and its still not working. giving me the same error.
I have even tried uninstalling everything, with no luck
*Expert Elite*
TravisNave
Message 14 of 33 (79 Views)
07-08-2013 01:32 PM in reply to: estauss
I was thinking this old program uses the sgiawd.exe vendor daemon file.  Is that correct?  You might need to add this file to the other .exe files on your NLM...
<attached is a zipped copy of sgiawd.exe>
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Message 15 of 33 (73 Views)
07-08-2013 01:55 PM in reply to: TravisNave
Hi Travis,
Not sure if that requires that or not. but I downloaded it and put it in the same folder that contains the lmgd, adskflex, lmutil, etc...and rebooted the server and still no luck.
*Expert Elite*
TravisNave
Message 16 of 33 (67 Views)
07-08-2013 02:25 PM in reply to: estauss
You unzipped it right?  Can you copy/paste the header part of your license file here?  That will be the first 3 lines.
I wanna make sure what vendor daemon it uses and what port.  For example, one of my older files looks like this:
SERVER servername 0012345678ab 7111
USE_SERVER
VENDOR sgiawd
Definitely uses sgiawd on port 7111.  Yours might shed some light on the case.
Message 17 of 33 (56 Views)
07-08-2013 06:44 PM in reply to: TravisNave
Hi Travis,
Here is the top 3 lines
SERVER FLEX2.AERO.UND.EDU 005056AA1A70
USE_SERVER
VENDOR adskflex port=2080
*Expert Elite*
TravisNave
Message 18 of 33 (55 Views)
07-08-2013 06:46 PM in reply to: estauss
Thanks. And you didn't combine your Max license with another license right?
Message 19 of 33 (47 Views)
07-08-2013 10:04 PM in reply to: TravisNave
Hi Travis,
No I have not. This is actually the first license I have tried putting on this server. This server does nothing else. Its purpose is to host licenses.
*Expert Elite*
TravisNave
Message 20 of 33 (42 Views)
07-09-2013 04:45 AM in reply to: estauss
Do you have the box checked to use the domain name too? Your .lic is FQDN.
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
